Anyone here ever fab up a rear disc brake conversion using GM calipers, and Jeep rotors? The weld on brackets can be had for about $30, new rotors a pair are about $60, and the calipers are around $40 a pair. I used a similar setup on a old dragster, and it stopped just as good, if not better than the higher end stuff, only draw back IMO is the weight. I always made the first turn off return road at the local 8th mile only track running 143 MPH. These conversions is very poplular in the dirt/circle track crowds.
