Hotchkis greasable LCA pivots. Anyone use?
#2496814
05/16/18 12:49 PM
05/16/18 12:49 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
If ao what did you torque the nuts to?
I bought these for my rebuild and have had a time with them. Bought them from Mancini. Came with no instructions, and were different from the pics. My package came with the poly bushings in outer shells that were powder coated and marked Proforged.
I tried pressing them in as a unit and ended up distorting a bushing. Had to take them back apart and hammer the bushings out of the shells. Pressed shells into arms, then pressed in bushings, and then pressed in pivots. Whew. Done right?
Nope. No instructions so no torque spec. Found a FABO post saying someone snapped one trying to hit the factory torque spec. So I called hotchkis yesterday and the tech guy said he didn't have a torque spec, knew it wasn't the factory 125 ft/lb, and couldn't believe someone broke a set because they were hardened steel.... So I said "Well that doesn't help, and its your part sooo..." Guy puts me on hold while he finds one of the engineers. Comes back and says he has two answers from the engineers "really good and tight" and "somewhere around 70 ft/lb or so".
So, I'm a bit shocked that a company like hotchkis can't give a firm answer on this. Anyone else use these and how did you set them up?
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Hotchkis greasable LCA pivots. Anyone use?
[Re: Michael Ecks]
#2496827
05/16/18 01:28 PM
05/16/18 01:28 PM
Posts: 22,724 Bitopia
jcc
Bitopia
I am not sure I understand the main concern is on specific torgue specs. They don't restrain anything, they just need to stay in place, correct? Hardly any of the normal forces on the road are not loading the nut fastener. I'm basing this off the grease-able Firm feel LCA pivots I have.
[Re: jcc]
#2496829
05/16/18 01:36 PM
05/16/18 01:36 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
I am not sure I understand the main concern is on specific torgue specs. They don't restrain anything, they just need to stay in place, correct? Hardly any of the normal forces on the road are not loading the nut fastener. I'm basing this off the grease-able Firm feel LCA pivots I have. You just answered my question on where to purchase, thanks. Do they move freely?
[Re: cudaman1969]
#2496831
05/16/18 01:40 PM
05/16/18 01:40 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Torqued mine to factory spec, but not driven yet. Should I be concerned? By the way, you can buy the ProForged ones from Rockauto for $84.95.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
[Re: cudaman1969]
#2496915
05/16/18 07:00 PM
05/16/18 07:00 PM
jcc
Bitopia
I am not sure I understand the main concern is on specific torgue specs. They don't restrain anything, they just need to stay in place, correct? Hardly any of the normal forces on the road are not loading the nut fastener. I'm basing this off the grease-able Firm feel LCA pivots I have. You just answered my question on where to purchase, thanks. Do they move freely? I used Delrin bushings, and yes.
[Re: Michael Ecks]
#2496932
05/16/18 07:43 PM
05/16/18 07:43 PM
Michael Ecks
Columbus, GA
So did the Firm Feel or Proforged come with instructions. I get that unlike factory bonded rubber units, they are just acting as supports for the LCA via the bushing. But still when the people that make them can't set a torque spec or bother to write install instructions for their own hardware its a little concerning.
I guess I'll tighten somewhere between real good and tight and 70 ftlb and call it good.
[Re: Michael Ecks]
#2497881
05/19/18 02:27 PM
05/19/18 02:27 PM
Posts: 8,501 Candler,NC / Myrtle Beach, SC
JDMopar
Mike....maybe dig around online and see if you can find a tech number at Proforged. They seem to have a pretty decent reputation, as far as suspension parts go. Unless I'm wrong, the pin is just going to spin in the poly bushing anyway, instead of being tight and twisting the bushing like the rubber ones do. I think the grease is to keep it from sounding like a Ford Falcon when you're driving. "Squeeeeeek, squeaky, squeekity squeak!" LOL
[Re: JDMopar]
#2497902
05/19/18 04:21 PM
05/19/18 04:21 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Mine are Firm Feel, factory torque
Abe Lincoln
