69 Barracuda rear defog #2496222
05/14/18 11:53 PM
05/14/18 11:53 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
I am trying to get the interior back together in my car ...after being apart for 11 years. What is the configuration for the rear defog setup on a 69 Fastback? I know the blower motor and intake grill are mounted on the rear passenger side panel. I assume there is a flex tube/hose and rear outlet duct vent for mine but don’t have the pieces or know what the vent looks like or how it mounts? I would appreciate if someone can post a photo of where the outlet duct is mounted and what it looks like. Maybe there is a diagram in the 1969 Sevice Manual which I do not have.
Re: 69 Barracuda rear defog [Re: RoadRunnerJD] #2496268
05/15/18 01:07 AM
05/15/18 01:07 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Google "69 barracuda rear defroster" or similar, and you'll get photos and parts for sale.
It doesn't seem to be covered in the 69 Plymouth Factory Service Manual, not under 08 Electrical, not under 24 Heaters and Air Conditioning.
Re: 69 Barracuda rear defog [Re: RoadRunnerJD] #2496278
05/15/18 01:46 AM
05/15/18 01:46 AM
Warrenton, VA
Warrenton, VA
I just tried it but no luck finding the ductwork for a fastback Barracuda. I guess I’ll have to find a Fastback and see what ai can see
Re: 69 Barracuda rear defog [Re: RoadRunnerJD] #2496288
05/15/18 02:38 AM
05/15/18 02:38 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Wonder if Ehrenberg has some intel from his stash?
Re: 69 Barracuda rear defog [Re: RoadRunnerJD] #2496291
05/15/18 03:24 AM
05/15/18 03:24 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Click the links.
Google search: 68 Barracuda rear defroster Then select images. Then scroll through the pictures
Google search 68 fastback defroster Then select images and do as above.
https://m.ebay.ca/itm/201563238194?
https://www.forabodiesonly.com/mopar/thr...uctions.369846/
https://www.forabodiesonly.com/mopar/thr...ger-kit.369258/
Re: 69 Barracuda rear defog [Re: autoxcuda] #2496565
05/15/18 06:31 PM
05/15/18 06:31 PM
Warrenton, VA
Warrenton, VA
One of the posts from forabodiesonly was a big help. Thank you. The outlet opening is actually a slot in the painted metal interior triim panel.
