V/P clearance question. '78 360, adding wild cam
#2495693
05/13/18 09:50 PM
05/13/18 09:50 PM
RapidRobert
bone stock '78 360. I am wanting to cam it & get out there on the track & be a little competitive (2bbl & 9-1 CR limit). Have a Hughes SEH3636AL-6 hyd cam .546"/.546 lift that I would like to toss in. with how far down the pistons are can I likely get by without checking for interference? I know ideally I absolutely should degree it & check the VP clearance etc but I am under a time crunch. thank you for your time. EDIT The concensus is the 2bbl 360 cam has .410/.410" lift.
Re: V/P clearance question. '78 360, adding wild cam
[Re: RapidRobert]
#2496017
05/14/18 03:30 PM
05/14/18 03:30 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
[Re: RapidRobert]
#2496018
05/14/18 03:36 PM
05/14/18 03:36 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
if your running stock pistons you should be fine, they are so far down the block it is pathetic, something like 1/8 inch plus a dish. I also doubt your going to actually get 9 to 1 with them but with some heavy milling and thin head gaskets... maybe but you will still have a lot of clearance because the pistons are so far down.
[Re: RapidRobert]
#2496022
05/14/18 03:46 PM
05/14/18 03:46 PM
RapidRobert
Maxx that probably clinches it as a no go right there. Cab you are right I know better (just a bit desperate). Dave 9-1 is the class CR limit (not sure why I threw that in) as you are correct, the actual SCR is probably in the low 8's if not the high 7's. Alright I will run it as is (for now), thanks guys.
[Re: dogdays]
#2496066
05/14/18 05:46 PM
05/14/18 05:46 PM
RapidRobert
Hello Dog, I've been wondering where you been. Thank you for the detailed 360 specs that likely could not have been found anywhere else, appreciated!. It is a bone stock 78 360 & my Cornhusker buddy had suggested a cam swap to wake it up a bit so I thought I might toss the Hughes cam I have in there but since it will have retainer area issues I am gonna just swap the truck pan off of it & toss it in there just to get running (& a new timing chain). It might blow up but until then it likely will run long enough to let me evaluate the rest of the car (74 dart/904/7&1/4) out on the track (gonna be interesting to see if the welded spiders 4:10 7&1/4 hold up!). yes I wont even be close to the 9-1 upper limit allowed & it will be a dog anyhow beings it is a high mileage stocker (EQ heads/weiand stealth/eddie performer intakes are allowed) but I just need to get out there.
[Re: MR_P_BODY]
#2496071
05/14/18 06:02 PM
05/14/18 06:02 PM
RapidRobert
that crossed my mind but with it being a high rpm circle track raceing I'm thinking I should leave it be (or even retard it as I have the 3 keyways) but I am for sure open to suggestions.
[Re: MR_P_BODY]
#2496076
05/14/18 06:12 PM
05/14/18 06:12 PM
RapidRobert
I was thinking 6K + with the 5:57 8&3/4 but with this 7&1/4 I ain't sure but I wanted to try something trick this year but the head gasket from hell situation then the low oil psi has sidetracked me. I'm about ready to pay someone to build me one!.
[Re: lewtot184]
#2496077
05/14/18 06:14 PM
05/14/18 06:14 PM
RapidRobert
that's an engle kv1 profile. 269@.020", 239@.050, 155@.200, .364 lobe lift. probably around 280-285 on the seat. That would explain why Maxx could not find it on Hughes' site. & I ain't sure I really wanna make a purchase from them again (good tech but too much rudeness).
[Re: dvw]
#2496083
05/14/18 06:26 PM
05/14/18 06:26 PM
Porter67
Along the same thinking with the spring off and a new seal to hold the valve in place goto full lift and then push the valve down that the new seal is holding up and use a fine tip marker or wrap a section of masking tape the measure off that. I always clay them but if I want to get a general idea early on I do the above. Many ways to get a ball park figure. Its not the lift, it's the duration. Quick and dirty bring it to TDC overlap. wrap a rag around the rocker arm. Grab the rocker arm with big channel locks and open the valve. How far did it move before it hit? That will get you ballpark. Doug
[Re: Porter67]
#2496352
05/15/18 11:22 AM
05/15/18 11:22 AM
RapidRobert
iirc it had C clips. My racing partner Johnny is gonna be driving & he owes me money so for sure I wanna take care of him (at least for the time being) at least till we get even steven. I will grab a rag & check clearance at TDC overlap to get a ballpark. EDIT I have a PM out to Dwayne "fast68plymouth" for a cam recommendation
[Re: Racer33]
#2496392
05/15/18 12:16 PM
05/15/18 12:16 PM
RapidRobert
He's payin me off as fast as he can
