Looking for recommendations on a mechanical fuel pump 440 #2494844
05/11/18 06:16 PM
05/11/18 06:16 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Hey Guys,
The fuel pump on my car is letting the fuel drain back out of the carb. It doesn't want to start after a couple of days sitting. Any recommendations on who makes a good mechanical pump these days for a stock 440? I believe the one I have on it now is a Carter M4862 and about 12 years old. Really hasn't been used enough to fail.
Thanks!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2494866
05/11/18 07:10 PM
05/11/18 07:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By Dixie
Hey Guys,
Thanks!
Randy
Get another 4862,that's s all I've ran in 35 yrs. twocents
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2494890
05/11/18 08:30 PM
05/11/18 08:30 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Why not get a rebuild kit & rebuild it.
Try Then and Now Automotive for a kit.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: 62maxwgn] #2494904
05/11/18 09:18 PM
05/11/18 09:18 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Hey Guys,
Thanks!
Randy
Uh-huh...
(And maybe a little fuel conditioner in with the wonderful alcohol 'enhanced' fuel...
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2494927
05/11/18 10:26 PM
05/11/18 10:26 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Can this happen? The fuel enters the top of the carb.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2494962
05/12/18 12:10 AM
05/12/18 12:10 AM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
If you can find a clay smith pump they are pretty stout and are rebuildable. They are also big enough to meet the needs of the most demanding motors. They fed my 600hp just fine and I am hoping it will be enough to feed 775 I should have now.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2494988
05/12/18 02:16 AM
05/12/18 02:16 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
not posable for fuel to go back to pump after it enters the carb !
you eather have a fuel evaporation problem due to heat or you have a internal leak in the carb allowing the fuel to leek into the intake and cylinders !
what carb do you have ?
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: calrobb2000] #2495075
05/12/18 01:00 PM
05/12/18 01:00 PM
moparx Online content
moparx  Online Content
most, if not all of the "dry carb" after sitting a few days problems, can be traced to today's fuel just evaporating from the float bowls. very common with carter style carbs.
beer
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2495094
05/12/18 02:07 PM
05/12/18 02:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
fuel evaporation problem. fuel cannot return to the pump.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: moparx] #2495095
05/12/18 02:09 PM
05/12/18 02:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
When I went from a open air air filter to a enclosed factory air filter the evaporation greatly decreased with my eddie carburetor.
My car sits for months at time now and starts after about 6-10 revolutions and some petal pumping with a ordinarily mechanical fuel pump.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: calrobb2000] #2495103
05/12/18 02:18 PM
05/12/18 02:18 PM
Originally Posted By calrobb2000
hi
iagree Don't waste your money on a new pump tsk
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Cab_Burge] #2495411
05/13/18 09:08 AM
05/13/18 09:08 AM
IN
ahy Offline
ahy  Offline
IN
hi
Agree the pump is likely fine... especially if it runs OK after starting. Fuel evaporation is very likely. I have switched my carb vehicles to electric pump for this reason. Key on for a few seconds re-primes the system and starts right up. This also can eliminate vapor lock.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2495697
05/13/18 09:58 PM
05/13/18 09:58 PM
Dixie Offline OP
Dixie  Offline OP
The carb is a factory Carter AVS. I originally thought that today's cheap gas was just evaporating, but I recently put 110 racing fuel in it and had the same problem. Carb dry after sitting a few days.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2495705
05/13/18 10:32 PM
05/13/18 10:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, the bowl vent doesn't care what fuel is in the carb. AFB & AVS carbs evaporated back in the day, too. Usually takes a week or two of sitting. I fill the bowls using the electric pump on the cars that have them, or fill manually through the vent tubes, or just spin 'em for a bit.
They're certainly not like EFI.
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2495728
05/13/18 11:17 PM
05/13/18 11:17 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Here's what works for me:
'Thick' gasket under an Edelbrock AFB...
Aluminum M-1 intake...
HP mechanical pump...
Proper supply;return;venting;gas cap...
Zero percolation issues...
Zero starting issues...
20+ years of road time, and a LOT of high heat conditions...
(ALWAYS a mixture of 110 and the pump sh!t...
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2495970
05/14/18 02:15 PM
05/14/18 02:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Squirt bottle (small with a cap) filled with gas, remove air cleaner, pour in the front vent, replace air cleaner and start. Simple huh?
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: cudaman1969] #2496137
05/14/18 08:09 PM
05/14/18 08:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I had the same problem, so answer this. The fuel evaporates out of the carb, ok, I get that, but then tell me how the fuel in the fuel filter disappears from the fuel line all the way down to the pump?
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2496149
05/14/18 08:38 PM
05/14/18 08:38 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I actually like to let it crank a bit to build oil PSI. I wont set the choke until after I get a few revolutions out of the engine.....but thats just me! LOL
1MYTGTX
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: cudaman1969] #2496156
05/14/18 09:04 PM
05/14/18 09:04 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
Try that with a shaker set up....lol!
Re: Looking for recommendations on a mechanical fuel pump 440 [Re: Dixie] #2496241
05/15/18 12:18 AM
05/15/18 12:18 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
OK... I have a brand new backflow preventer valve that I bought but didn't need. And I have a nearly new mechanical Racepump that I'm not using. If interested, let me know.
