Re: Which QFT carb. Recommendations?
[Re: W5Duster436]
#249568
03/10/09 01:59 PM
03/10/09 01:59 PM
Posts: 156 Michigan, US
ben1692
Michigan, US
call them they can help 270 793 0900 they are very helpful
[Re: W5Duster436]
#249572
03/10/09 02:09 PM
03/10/09 02:09 PM
Posts: 12,393 Taxes & Virus's R-US, NY
Dragula
For the stroker, my vote is the 950 annular or a 1050 dominator with annulars...I run an 850 annular on my mild 360, and its awesome. The annular boosters are bigger than down leg ones, and restrict flow some. They also allow the carb to respond at low rpm like its 200cfm smaller due to the increased booster sensativity with annulars, therefore, running a bigger one is not even remotely an issue. Wish I had a vid of what this thing sounds like when you dump the throttle...Carb responds almost as quick as an efi motor, and is always right there if you even touch the gas pedel...Makes a neat sound when you dump the throttle....
[Re: Dragula]
#249574
03/10/09 02:18 PM
03/10/09 02:18 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I really like Quickfuel carbs! I have run a 950 on my 499 for a few years and have won a lot of races with it. The 950 has always been faster than any 1050 I've tried. I bought a 850 for my Dart Sport last year for the 394 sb that was in it. It was an improvement over the other 850 that was on it for sure. I am currently building a 422' for the DArt and will use the 850 again. If the carb is set up right the increases are usually minimal.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
