air filter
#2495570
05/13/18 03:48 PM
05/13/18 03:48 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
What was the name of the after market air filer that was a wedge shape ?
Re: air filter
[Re: rowin4]
#2495739
05/13/18 11:42 PM
05/13/18 11:42 PM
rowin4
Thank you sir, did some research and found some pictures. I see it uses perforated metal under the foam filter media but didn't see how the foam is held on. Anyone using one of these UNI filters?
Re: air filter
[Re: rowin4]
#2495889
05/14/18 11:40 AM
05/14/18 11:40 AM
rowin4
I see by looking at the pictures more closely that the foam filter is sandwiched between the perforated sheets. Seems that the holes are not very big and would restrict air.
Re: air filter
[Re: rowin4]
#2495966
05/14/18 02:08 PM
05/14/18 02:08 PM
Thumperdart
State of confusion
Love my round WIX Racing paper filters...........
Re: air filter
[Re: rowin4]
#2495968
05/14/18 02:11 PM
05/14/18 02:11 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
Elvis had one on Barney at one time. He claimed it worked great.
Re: air filter
[Re: rowin4]
#2496038
05/14/18 04:28 PM
05/14/18 04:28 PM
rowin4
The reason I was looking for that type of filter is my fiberglass chevy type cowl hood has a brace across the back of the cowl and hits the standard 14" air cleaner. I figured if I mounted the uni with the wedge towards the windshield the brace would clear.
Re: air filter
[Re: rowin4]
#2496139
05/14/18 08:11 PM
05/14/18 08:11 PM
Posts: 11,705 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I used a K&N velocity style assembly inside my scoop with an isolation pan. Didn't oil it. Didn't hurt performance. Might have helped actually.
Re: air filter
[Re: rowin4]
#2496310
05/15/18 08:53 AM
05/15/18 08:53 AM
Posts: 2,527 PA
moparacer
PA
I have ran a Uni for years. Would I run one on a street car for 30,000 miles? No, but it is the best option for a race car if you want no ET loss and some sort of filtering capability that is better than a piece of screen. Every paper element filter I ever tried slowed the car down.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: air filter
[Re: rowin4]
#2496683
05/15/18 10:46 PM
05/15/18 10:46 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I know my cylinder walls were noticeable better on the winter freshen after we put the filter on it. Just a lot of dusty pits, rocks and trash thrown behind the water box - it just makes sense.
Re: air filter
[Re: rowin4]
#2496726
05/16/18 12:59 AM
05/16/18 12:59 AM
rowin4
I have no problem with K&N filters , I have one on my 67 barracuda and my 04 dodge since new. As I stated above the round filter won't fit with the engine set back and the hood brace. I want to run a filter, always have on all my race cars. So does K&N make filter that similar to the UNI wedge type ? Or how close can the filter media be to the top of the 4500 Dominator carb with one of their flat rectangle drop in type filters. I can make a box to fit to in.
