Re: Welding help needed
[Re: sgcuda]
#2495345
05/13/18 12:34 AM
05/13/18 12:34 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Being it’s late Saturday night and you want to work tomorrow I would check the welding supplies at Tractor Supply since they would be open tomorrow morning and see if the have a hose repair kit. We repaired our hoses all the time in the steel mill.
[Re: pittsburghracer]
#2495478
05/13/18 12:37 PM
05/13/18 12:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put a piece of fuel line over it.. it will get you by.. if needed tape off the hose ends that you put on.. its low pressure if your talking the argon line
[Re: jcc]
#2495581
05/13/18 04:25 PM
05/13/18 04:25 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The pressure is so low a couple of turns of electrical tape should do the trick, until you do more damage next time. I always keep a complete tig cable/hose set-up in the shelf for my late night must do bashes when the unexpected happens, which seems a lot. Did you have a hose cover installed? Everything this guy says. Just plastic tubing with a wire clamp at the fittings. Now when you poke a hole in the conductor line with a water cooled torch, then it gets messy.
[Re: sgcuda]
#2495610
05/13/18 06:12 PM
05/13/18 06:12 PM
Posts: 25,866 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Shrink wrap tubing with a little RTV right at the burned hole.
[Re: John_Kunkel]
#2495622
05/13/18 06:33 PM
05/13/18 06:33 PM
MR_P_BODY
I melted about a 3" hole in my tube and all I had at the time was fuel line to fix it.. with some elec tape and the hose it was great... its still there after 3 years.. protective cover does wonders
[Re: MR_P_BODY]
#2495627
05/13/18 06:45 PM
05/13/18 06:45 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I guess my 33 years of Millwright work and especially the last 10 years with our inspections that we had to pass make me overly cautious. If putting a couple layers of electrical tape works for you, go for it. LOL.
[Re: sgcuda]
#2495634
05/13/18 07:07 PM
05/13/18 07:07 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
How much do you lose if you just shorten it?
[Re: sgcuda]
#2495659
05/13/18 07:58 PM
05/13/18 07:58 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
My handle has a control knob at the torch head, not foot peddle controlled, so the pressure gets up to bottle pressure in the line. I took pittsburghracer's advise, did some research and found out that repair kits aren't much more than a barbed splice. I cut the line where I burned it. Surprised to find how thick the line was. It's like a soft plastic or hard rubber line. 3/16" id. Ran down to Lowes, got a splice, pushed it on the line, holds pressure fine. Thanks, guys.
[image][/image]
[Re: sgcuda]
#2495699
05/13/18 10:16 PM
05/13/18 10:16 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"so the pressure gets up to bottle pressure in the line."
Never seen that, and have no idea what the advantage is by that design. Is this an air cooled torched?
[Re: jcc]
#2495737
05/13/18 11:39 PM
05/13/18 11:39 PM
MR_P_BODY
Never seen that, and have no idea what the advantage is by that design. Is this an air cooled torched? I think the regulator is bad.. shouldnt be that way and its just wasting gas
[Re: sgcuda]
#2495740
05/13/18 11:45 PM
05/13/18 11:45 PM
sgcuda
Maybe not bottle pressure, but regulator controls flow, not pressure. Knob at torch handle turns on gas, along with power trigger. Snap On MM-140. Mig and Tig machine.
[image][/image]
[Re: sgcuda]
#2495744
05/13/18 11:55 PM
05/13/18 11:55 PM
MR_P_BODY
My reg sets the pressure but I have a flow meter also... I set the pressure a little above what I will be flowing then fine tune the flow with the flow meter.. I have 2 gauges on my tank.. one shows tank pressure the other sets the flow(low pressure in CCM)
[Re: sgcuda]
#2495756
05/14/18 12:15 AM
05/14/18 12:15 AM
sgcuda
Mine has just 1 gauge for bottle pressure, and the regulator with a flow meter. That's all I've ever used for welding, so I guess that's just what I'm used to using.
[image][/image]
[Re: sgcuda]
#2495978
05/14/18 02:23 PM
05/14/18 02:23 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
Mine has just 1 gauge for bottle pressure, and the regulator with a flow meter. That's all I've ever used for welding, so I guess that's just what I'm used to using. "Flow meter"Do you mean the plastic tube with the ball that floats up and down on a graduated scale? If I can remember rite my tank pressure is up in the thousands of pounds of pressure, that touch line would pop quickly if the pressure "got up to bottle pressure" . I had the same thing you have, the handle valve was an on off type thing, never much pressure.
[Re: sgcuda]
#2496009
05/14/18 03:13 PM
05/14/18 03:13 PM
TRENDZ
Milwaukee WI
The flow regulator is after the pressure regulator. Most regulators are fixed at about 25psi, then flow is controlled by a pin orfice. With a torch that has a flow control, you open the regulator mounted flow control. You will never have straight bottle pressure in the torch lines.
