Re: Milodon Externally Adjustable Oil Pressure Regulator
[Re: Cab_Burge]
#2495266
05/12/18 09:14 PM
05/12/18 09:14 PM
dartman366
Mt. Vernon, Ohio
when you buy one the instruction sheet that comes with it will tell you your starting point altho I went by the instructions and it was 120# at start-up, with mine the adjust seemed to affect the upper and lower pressure a like amount.
[Re: 70satelliteguy]
#2495276
05/12/18 09:27 PM
05/12/18 09:27 PM
dartman366
Mt. Vernon, Ohio
"I went by the instructions and it was 120# at start-up," Dartman 120 seems pretty high? Will setting it that high adversely affect anything? Thanks Mike didn't mention that I shut it off and adjusted it out till I got 75# and I don't think it was turned in origionally as much as Cab said to set it but I am sure he has done it a time or three
#2495454
05/13/18 11:22 AM
05/13/18 11:22 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
those almost always run way too high. I have had to cut almost every one to get a reasonable and useable pressure.
RIP Monte Smith
#2495474
05/13/18 12:31 PM
05/13/18 12:31 PM
Posts: 4,209 New York
polyspheric
New York
Spit out a cam gallery plug Blow the filter off the engine
Boffin Emeritus
[Re: cryplydog]
#2495492
05/13/18 01:16 PM
05/13/18 01:16 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Melling high volume pump. Not the high pressure pump. Has the Milodon adjustable regulator that replaces the one that came with the pump. I have 85 startup right now. Is this too high? Will it stress the oil/dist. shaft or cause hp loss? Thanks mIke "Spit out a cam gallery plug Blow the filter off the engine" ??? Has this happened to you? At what pressure? Thanks for the reply's Mike
[Re: dartman366]
#2495538
05/13/18 02:36 PM
05/13/18 02:36 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
didn't mention that I shut it off and adjusted it out till I got 75# and I don't think it was turned in origionally as much as Cab said to set it but I am sure he has done it a time or three I've never used those on any pump I have helped another racer who had one though, not sure if it was stock or if he had change the bypass spring already
