Re: dana 60
[Re: br67]
#2495262
05/12/18 09:11 PM
05/12/18 09:11 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Yes sir it will 3.54,3.73, 3.91 and 4.10 gears will all fit on the early 3 series carriers, posi and opened
Re: dana 60
[Re: rebel]
#2495443
05/13/18 10:52 AM
05/13/18 10:52 AM
Posts: 3,525 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
What about 4.88s? I have an Ultimate Dana 60 that currently has 4.10 gears & I have a contact who will swap his 4.88s for my 4.10s. Are they going to fit? To the best of my knowledge no... There are spacers available but not recommended for manual shift or high horsepower applications. However the 4.10 is not going to work in your friends car either unless you swapped carriers as well as gears.
Re: dana 60
[Re: 340Cuda]
#2495548
05/13/18 02:48 PM
05/13/18 02:48 PM
Cab_Burge
What about 4.88s? I have an Ultimate Dana 60 that currently has 4.10 gears & I have a contact who will swap his 4.88s for my 4.10s. Are they going to fit? However the 4.10 is not going to work in your friends car either unless you swapped carriers as well as gears. Most 3 series carriers or spools are from 3.54 to 4.10 and the 4 series are from 4.56 to 5.38. Some after market 4.30 ratio gear will fit either one as long as you order the proper part number for your carrier Dana Corp. use to only make one offset on the all of their Dana 60 ring gears so you had to change carriers to switch to the lower gears, Dana started making Dana 60 gears for both series some time in the mid 1990s is what I have heard recently How to tell which part number for which carrier is the hard part All the Dana 70 I've worked on are that way so you can order any ratio for any year Dana 70 carrier
Re: dana 60
[Re: 340Cuda]
#2495568
05/13/18 03:46 PM
05/13/18 03:46 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
What about 4.88s? I have an Ultimate Dana 60 that currently has 4.10 gears & I have a contact who will swap his 4.88s for my 4.10s. Are they going to fit? To the best of my knowledge no... There are spacers available but not recommended for manual shift or high horsepower applications. However the 4.10 is not going to work in your friends car either unless you swapped carriers as well as gears. I have used a spacer in the past with no problem , just use on lock tight on the bolts and proper torque.
