Re: electric fans
[Re: RustyM]
#2494854
05/11/18 06:50 PM
05/11/18 06:50 PM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
SPAL makes a nice product. I'm sure there are others.
Re: electric fans
[Re: RustyM]
#2495092
05/12/18 02:06 PM
05/12/18 02:06 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I bought a derale for my car. Made night and day difference over cheap parts store fan that was on the car when I bought it. Spal and derale both good fans. I found the better fans that have good motors pull 20+ amps. If they aren't pulling that many amps and have good CFM ratings, run. They won't cut the mustard
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: electric fans
[Re: RustyM]
#2495108
05/12/18 02:22 PM
05/12/18 02:22 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
If I had the money I would run some delta pag fans, they look very trick.
Since I don't I run a set of dual fans from a dodge intrepid. They have a high and a low speed and have worked well even though my radiator is a little undersized.
68 Barracuda Formula S 340
Re: electric fans
[Re: RustyM]
#2495394
05/13/18 04:56 AM
05/13/18 04:56 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
FWIW, I bought some 13" Be-Cools fans when Summit was running a sale. They are SPAL fans with the mounting strap kit.
I had a Champion 4-core radiator (4 x 0.63" tubes, core 2.75" deep.) The thickness of the radiator made it difficult for clearance to the water pump. Edited: tank width per spec sheet is 3.2" wide.
I changed to a Griffin (2 x 1.25", 2.68" deep core, tanks are about same width as core) exact fit radiator (about 1/2" more water pump to radiator clearance), and I used two 13" Be-cool (SPAL) fans (2" deep, 1200-1250 cfm each) on 26" radiator in '69 Coronet with 440 engine.
Re: electric fans
[Re: RustyM]
#2495550
05/13/18 02:51 PM
05/13/18 02:51 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I wonder if I can adapt that to my radiator shroud?? sure save some money. I need 2800 to 3000 cfm for the 4 core radiator.
Not putting car on street at this time but, who know later,,,,, RustyM my two cents would be build the tool for what you want to do now. Weight on the nose of a 10sec bracket car is evil and just makes it harder to get the car to work.
"Just a Bracket car dressed up like a streetcar"
Re: electric fans
[Re: RustyM]
#2496734
05/16/18 01:43 AM
05/16/18 01:43 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I had an HHR fan on mine, but recently switched it out. I am using a dual fan setup from a Ford Contour. Works really well. I like it a lot better than my HHR fan
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
