Re: Looking for recommendations on a mechanical fuel pump 440
[Re: 62maxwgn]
#2494904
05/11/18 09:18 PM
05/11/18 09:18 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Hey Guys,
The fuel pump on my car is letting the fuel drain back out of the carb. It doesn't want to start after a couple of days sitting. Any recommendations on who makes a good mechanical pump these days for a stock 440? I believe the one I have on it now is a Carter M4862 and about 12 years old. Really hasn't been used enough to fail.
Thanks! Randy Get another 4862,that's s all I've ran in 35 yrs. Uh-huh... (And maybe a little fuel conditioner in with the wonderful alcohol 'enhanced' fuel...
[Re: Dixie]
#2495728
05/13/18 11:17 PM
05/13/18 11:17 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
The carb is a factory Carter AVS. I originally thought that today's cheap gas was just evaporating, but I recently put 110 racing fuel in it and had the same problem. Carb dry after sitting a few days. Here's what works for me: 'Thick' gasket under an Edelbrock AFB... Aluminum M-1 intake... HP mechanical pump... Proper supply;return;venting;gas cap... Zero percolation issues... Zero starting issues... 20+ years of road time, and a LOT of high heat conditions... (ALWAYS a mixture of 110 and the pump sh!t...
[Re: Dixie]
#2496149
05/14/18 08:38 PM
05/14/18 08:38 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
I actually like to let it crank a bit to build oil PSI. I wont set the choke until after I get a few revolutions out of the engine.....but thats just me! LOL
1MYTGTX
[Re: cudaman1969]
#2496156
05/14/18 09:04 PM
05/14/18 09:04 PM
Posts: 2,655 western PA
mopar4ya
western PA
Squirt bottle (small with a cap) filled with gas, remove air cleaner, pour in the front vent, replace air cleaner and start. Simple huh? Try that with a shaker set up....lol!
