Re: electric fans
[Re: RustyM]
#2497113
05/17/18 10:25 AM
05/17/18 10:25 AM
Posts: 1,178 Indy
FlyFish
Indy
2006 Chevy HHR fan, fully shrouded, pulls a ton of air, and only 50 bucks.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: electric fans
[Re: dart440_72]
#2497120
05/17/18 10:40 AM
05/17/18 10:40 AM
Posts: 667 IL
Dart451
IL
I had an HHR fan on mine, but recently switched it out. I am using a dual fan setup from a Ford Contour. Works really well. I like it a lot better than my HHR fan Have apart number or dimensions?
Re: electric fans
[Re: RustyM]
#2497438
05/18/18 02:36 AM
05/18/18 02:36 AM
Posts: 902 S.E. Minnesota
gtsdude
S.E. Minnesota
Here are the dimension of the HHR fan, you can take the plastic off the back of the motor and gain a little more room also.
Re: electric fans
[Re: B3422W5]
#2497627
05/18/18 06:08 PM
05/18/18 06:08 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I bought a derale for my car. Made night and day difference over cheap parts store fan that was on the car when I bought it. Spal and derale both good fans. I found the better fans that have good motors pull 20+ amps. If they aren't pulling that many amps and have good CFM ratings, run. They won't cut the mustard I agree 100%. The amps they pull indicates the strength of the motor. A weak fan can move lots of air when there is no restriction placed in front of it, but the CFM drops drastically when you put a radiator in front of it. A strong motor won't slow down as easily.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: electric fans
[Re: RustyM]
#2497671
05/18/18 08:17 PM
05/18/18 08:17 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
anyone know what the hhr fan weighs? I cant seem to find it. Pretty light..........
Re: electric fans
[Re: RustyM]
#2497711
05/18/18 10:22 PM
05/18/18 10:22 PM
Posts: 4,206 New York
polyspheric
New York
Haven't seen a direct A > B comparo of pusher vs. puller, but the puller always wins.
Boffin Emeritus
Re: electric fans
[Re: RustyM]
#2497792
05/19/18 06:55 AM
05/19/18 06:55 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I use a 16 inch pusher Spal 3 speed fan with 3 of their mounting straps. Best way to go,I'm tired of making some junk fans to fit!
Re: electric fans
[Re: RustyM]
#2500645
05/26/18 12:09 PM
05/26/18 12:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you ran E-85 you can leave at that temp all of the time.. but I dont know if its in your area.. on my car with E-85 I had more of a problem keeping it up to temp
Re: electric fans
[Re: RustyM]
#2500656
05/26/18 12:36 PM
05/26/18 12:36 PM
MR_P_BODY
Not sure Mr P- Have to look. This is a pump gas 511. question: Is E-85 more consistent than general pump gas? Yes it is if you check it before you buy it.. when I would buy it I would test it first and if it was within my specs I would pump out 2 drums.. it was very consistent
Re: electric fans
[Re: RustyM]
#2500780
05/26/18 08:34 PM
05/26/18 08:34 PM
polyspheric
New York
I agree, check it. But: E85 (like all alcohol-based) is safe to run richer than would hurt power in a race gas. The range of 99% max power is significantly wider. Your high air temp gives you an advantage! People in Alaska can't get methanol to work w/o a gas primer.
Boffin Emeritus
Re: electric fans
[Re: JAMESDART]
#2500854
05/26/18 11:49 PM
05/26/18 11:49 PM
hemi-itis
How deep is this contour fan in the center? Where the water pump would contact? If you were asking me..........https://www.jegs.com/i/SPAL/063/30102113/10002/-1
Re: electric fans
[Re: JAMESDART]
#2502034
05/30/18 12:12 AM
05/30/18 12:12 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
How deep is this contour fan in the center? Where the water pump would contact? 3.3 inches. It would contact in the between the center of the fans
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
