Page 1 of 3 1 2 3
Dart Small Block Mopar Blocks #2494732
05/11/18 12:31 PM
05/11/18 12:31 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Bob Book (of carburetor fame) is trying to talk Dick Maskin into building SBM race blocks.
This is the thread on Facebook where he is asking for comments:
https://www.facebook.com/groups/36255983...c&ref=notif
If you are asking "why does Bob care", he builds engines for Australian Pro Stock racers who use small blocks. He is at horsepower levels above the capacity of the R3/R4 blocks and wants something that will last.
If you are interested go to Facebook and add your $.02. If not never mind.
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494748
05/11/18 01:42 PM
05/11/18 01:42 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I know Kent Ritter is supply the blocks for the Australian guys right now so I'm guessing you haven't looked at that option.
I bought two new Ritters and one is in the process of being finished right now, just waiting on parts.
Re: Dart Small Block Mopar Blocks [Re: Biginchmopar] #2494756
05/11/18 02:05 PM
05/11/18 02:05 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Why bother!
You will have a solid bottom end with nothing for the top!
Unless you can start casting W8 or something better.
But your still stuck with outdated tech.
P5 top with a tallblock would be beneficial But a very limited market.
Matt
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494761
05/11/18 02:09 PM
05/11/18 02:09 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
If I was starting with new stuff. I would go Gen III.
Re: Dart Small Block Mopar Blocks [Re: rt66jim] #2494771
05/11/18 02:29 PM
05/11/18 02:29 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Me to if I was 25 years old. Trouble with the gen3 stuff is a lot of it isn’t interchangeable so you better really study up before you buy
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494777
05/11/18 02:52 PM
05/11/18 02:52 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
The new edlebrock Head has shown to make some nice power so there are heads available
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494780
05/11/18 03:01 PM
05/11/18 03:01 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I'd be curious to see the R4/R3, SBM, bolt-water-oil patterns laid over each other to see if there is any way to put it all in one box. You could always cast multiple lifter blanks and machine them as necessary for each customer. How much difference is there in the camshaft height between the two engines?
Adriel Paradise
Substation Design Engineer III
Re: Dart Small Block Mopar Blocks [Re: pittsburghracer] #2494786
05/11/18 03:14 PM
05/11/18 03:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Not as bad as you think.
VVT is one and Hellcat heads are another.
Pretty straight forward.
I've been pushing the G3 stuff for a long time. Good parts excellent heads and most importantly you can get the stuff right now.
But in all honesty I think this stuff has a shelf life also.
Matt
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494794
05/11/18 03:33 PM
05/11/18 03:33 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Surprised that no one is building the aluminum Ernie Elliot blocks into killer drag motors.
You can actually put your hands on them, and p7 heads can out do a W8.
Re: Dart Small Block Mopar Blocks [Re: TRENDZ] #2494817
05/11/18 04:50 PM
05/11/18 04:50 PM
PA.
"Little"John
"Little"John
PA.
Some of these engine and even the W8, W9 engines require a lot of rpm and top shelf parts to stay together. Rpm brings expense and is ok for the test n tune crowd but for the weekly racer unless you run slower 9’s with limited rpm become to costly.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494819
05/11/18 05:06 PM
05/11/18 05:06 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'd like to read the thread and check it out, but unfortunately it's a closed group and I don't want to join it to just read one thing.
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494836
05/11/18 06:06 PM
05/11/18 06:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
IMO kinda funny, Chevy guys who want to make power use the big block 550+ cu in. Small blocks can play IF you have your 4 stages of no2. Like one other post says, cubic inches rule, that means big block. Unless the rules require a small block, to me it's a waste of time and money. This crap that big blocks don't stay together, tell that to the Top Fuel-Funny Car guys.
Re: Dart Small Block Mopar Blocks [Re: cudaman1969] #2494842
05/11/18 06:14 PM
05/11/18 06:14 PM
PA.
"Little"John
"Little"John
PA.
I reread this post 5 times trying to figure it out. Are you saying big blocks DON'T blow up???
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dart Small Block Mopar Blocks [Re: pittsburghracer] #2494870
05/11/18 07:18 PM
05/11/18 07:18 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Hardly ever, especially the ones in Top Fuel dragsters and funny cars. whistling
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494871
05/11/18 07:18 PM
05/11/18 07:18 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If he would do it to be legal for Stock/Super Stock, it would make for a lot more potential customers - guys who typically are willing to spend a little money for good stuff.
Personally, I won't ever build another serious engine using an old OE block. I could build or use a light car, use a ~430 or so 2HP/CI small block, in a good block, and do what I want to do.
Re: Dart Small Block Mopar Blocks [Re: rt66jim] #2494874
05/11/18 07:26 PM
05/11/18 07:26 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I would go Gen III.
Someone has to say it in every single small block thread. Must have been your turn. laugh2 laugh2
Re: Dart Small Block Mopar Blocks [Re: CMcAllister] #2494875
05/11/18 07:27 PM
05/11/18 07:27 PM
PA.
"Little"John
"Little"John
PA.
I have an R block and assembly I will probably never build and the R3 in my black Duster. If they were available next year I would order one as I would like to build a Victor headed engine and lean on it. I’m to afraid to do much more grinding on my 360-1 heads.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dart Small Block Mopar Blocks [Re: 340Cuda] #2494879
05/11/18 07:34 PM
05/11/18 07:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Have you guys seen Bob's power levels? 400" 3hp/cube N/A
Doug
Re: Dart Small Block Mopar Blocks [Re: dvw] #2494882
05/11/18 07:51 PM
05/11/18 07:51 PM
Washington
madscientist Offline
Washington
Doug
It's damn impressive and probably down a bit because the blocks are at their limit.
It was idiotic to kill Pro Stock Truck. Make the trucks closer to pounds per cubic inch of the cars, and let the small block pick up 42 CID and Pro Stock car and truck would have been too close in ET.
Or let the trucks run nitrous.
Re: Dart Small Block Mopar Blocks [Re: pittsburghracer] #2494902
05/11/18 09:12 PM
05/11/18 09:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'll answer both yours and the one below.
Realistically if you want a fast, all out engine, why start with a sb? ANYTHING CAN BE BROKEN, but how long would those SB stay together? If they did all would have one. I'd start with the BAE, blown or turbo, should be in the 2-4000 hp range easily.
HP for dollar spent.
Just my opinion
Page 1 of 3 1 2 3
