Starter keep running after engine start/ on 440? #2494814
05/11/18 04:23 PM
05/11/18 04:23 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I have a question. I have a 71 dodge crew cab that has a 440 in it
The starter wants to stay running after it starts? Does that sound more like the starter relay orcthe starter?
Recent purchase and the 440 is suppose to be out of a superbee.
Thx for any help
Re: Starter keep running after engine start/ on 440? [Re: RUMBLON] #2494823
05/11/18 05:19 PM
05/11/18 05:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Any time I had that happen I just had to move either the positive battery cable or the 10 gauge wire around (or further apart). A close enough gap will cause it to arch across one another.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Starter keep running after engine start/ on 440? [Re: RUMBLON] #2494825
05/11/18 05:29 PM
05/11/18 05:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You mean the starter pinion isn't retracting after the engine is running?
The solenoid is either not getting a signal, or the solenoid has failed mechanically to retract.
It's been many years since I've experienced that problem, but I'd tend to bet on the starter solenoid, especially if it was subjected to header heat.
Probably wise to check the electrical circuit from the ignition switch through the starter, though; switch may be the problem.
Too bad you're not closer, I have one or two starters here you could try.
