Dart Small Block Mopar Blocks
#2494732
05/11/18 12:31 PM
05/11/18 12:31 PM
Posts: 3,525 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Bob Book (of carburetor fame) is trying to talk Dick Maskin into building SBM race blocks. This is the thread on Facebook where he is asking for comments: https://www.facebook.com/groups/36255983...c&ref=notifIf you are asking "why does Bob care", he builds engines for Australian Pro Stock racers who use small blocks. He is at horsepower levels above the capacity of the R3/R4 blocks and wants something that will last. If you are interested go to Facebook and add your $.02. If not never mind.
Re: Dart Small Block Mopar Blocks
[Re: rt66jim]
#2494771
05/11/18 02:29 PM
05/11/18 02:29 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If I was starting with new stuff. I would go Gen III. Me to if I was 25 years old. Trouble with the gen3 stuff is a lot of it isn’t interchangeable so you better really study up before you buy
[Re: 340Cuda]
#2494780
05/11/18 03:01 PM
05/11/18 03:01 PM
Posts: 577 Arkansas
Adrielp
Arkansas
I'd be curious to see the R4/R3, SBM, bolt-water-oil patterns laid over each other to see if there is any way to put it all in one box. You could always cast multiple lifter blanks and machine them as necessary for each customer. How much difference is there in the camshaft height between the two engines?
Adriel Paradise Substation Design Engineer III
[Re: pittsburghracer]
#2494786
05/11/18 03:14 PM
05/11/18 03:14 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
If I was starting with new stuff. I would go Gen III. Me to if I was 25 years old. Trouble with the gen3 stuff is a lot of it isn’t interchangeable so you better really study up before you buy Not as bad as you think. VVT is one and Hellcat heads are another. Pretty straight forward. I've been pushing the G3 stuff for a long time. Good parts excellent heads and most importantly you can get the stuff right now. But in all honesty I think this stuff has a shelf life also. Matt
[Re: 340Cuda]
#2494794
05/11/18 03:33 PM
05/11/18 03:33 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Surprised that no one is building the aluminum Ernie Elliot blocks into killer drag motors. You can actually put your hands on them, and p7 heads can out do a W8.
[Re: TRENDZ]
#2494817
05/11/18 04:50 PM
05/11/18 04:50 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Surprised that no one is building the aluminum Ernie Elliot blocks into killer drag motors. You can actually put your hands on them, and p7 heads can out do a W8. Some of these engine and even the W8, W9 engines require a lot of rpm and top shelf parts to stay together. Rpm brings expense and is ok for the test n tune crowd but for the weekly racer unless you run slower 9’s with limited rpm become to costly.
[Re: cudaman1969]
#2494842
05/11/18 06:14 PM
05/11/18 06:14 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
IMO kinda funny, Chevy guys who want to make power use the big block 550+ cu in. Small blocks can play IF you have your 4 stages of no2. Like one other post says, cubic inches rule, that means big block. Unless the rules require a small block, to me it's a waste of time and money. This crap that big blocks don't stay together, tell that to the Top Fuel-Funny Car guys. I reread this post 5 times trying to figure it out. Are you saying big blocks DON'T blow up???
#2494870
05/11/18 07:18 PM
05/11/18 07:18 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
IMO kinda funny, Chevy guys who want to make power use the big block 550+ cu in. Small blocks can play IF you have your 4 stages of no2. Like one other post says, cubic inches rule, that means big block. Unless the rules require a small block, to me it's a waste of time and money. This crap that big blocks don't stay together, tell that to the Top Fuel-Funny Car guys. I reread this post 5 times trying to figure it out. Are you saying big blocks DON'T blow up??? Hardly ever, especially the ones in Top Fuel dragsters and funny cars.
[Re: 340Cuda]
#2494871
05/11/18 07:18 PM
05/11/18 07:18 PM
Posts: 11,644 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If he would do it to be legal for Stock/Super Stock, it would make for a lot more potential customers - guys who typically are willing to spend a little money for good stuff.
Personally, I won't ever build another serious engine using an old OE block. I could build or use a light car, use a ~430 or so 2HP/CI small block, in a good block, and do what I want to do.
[Re: CMcAllister]
#2494875
05/11/18 07:27 PM
05/11/18 07:27 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have an R block and assembly I will probably never build and the R3 in my black Duster. If they were available next year I would order one as I would like to build a Victor headed engine and lean on it. I’m to afraid to do much more grinding on my 360-1 heads.
[Re: dvw]
#2494882
05/11/18 07:51 PM
05/11/18 07:51 PM
Posts: 4,457 Washington
madscientist
Washington
Have you guys seen Bob's power levels? 400" 3hp/cube N/A Doug It's damn impressive and probably down a bit because the blocks are at their limit. It was idiotic to kill Pro Stock Truck. Make the trucks closer to pounds per cubic inch of the cars, and let the small block pick up 42 CID and Pro Stock car and truck would have been too close in ET. Or let the trucks run nitrous.
#2494902
05/11/18 09:12 PM
05/11/18 09:12 PM
Posts: 8,325 fredericksburg,va
cudaman1969
fredericksburg,va
IMO kinda funny, Chevy guys who want to make power use the big block 550+ cu in. Small blocks can play IF you have your 4 stages of no2. Like one other post says, cubic inches rule, that means big block. Unless the rules require a small block, to me it's a waste of time and money. This crap that big blocks don't stay together, tell that to the Top Fuel-Funny Car guys. I reread this post 5 times trying to figure it out. Are you saying big blocks DON'T blow up??? I'll answer both yours and the one below. Realistically if you want a fast, all out engine, why start with a sb? ANYTHING CAN BE BROKEN, but how long would those SB stay together? If they did all would have one. I'd start with the BAE, blown or turbo, should be in the 2-4000 hp range easily. HP for dollar spent. Just my opinion
