Sealing up engine for vacuum pump? #2494339
05/10/18 12:04 PM
05/10/18 12:04 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Hi guys, we are getting our bracket car back out after sitting for a few years since my dads passing. We installed a vacuum pump(moroso 22640) on the engine and have discovered that the pump works and is pulling vacuum but it appears the engine is not sealed up as well as it should be for pulling vacuum. My question is where are the typical problem areas that you guys have run into where BBM's struggle to seal most. We want address these issues so we can get the engine sealed up. We plan to pressurize the crankcase and check for leaks but haven't quite gotten that done yet. Any help is appreciated. Thanks
Adriel Paradise
Substation Design Engineer III
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494374
05/10/18 01:32 PM
05/10/18 01:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Obviously the biggest gasket areas will need the most attention. The oil pan should have a thick and true rail and have all the windage tray stuff built into it instead of a sandwich type. The valley pan area is probably the hardest thing because with aluminum heads you are entirely dependent on the beads of silicone down the sides. Using a Jesel belt or a Milodon gear will help the front area big time. The distributor hole is also a challenge. Pull as much as you can and hopefully you can get north of 10 inches. High quality silicone like "The Right Stuff" will seal well but I've read here that it is a challenge to remove. You should be able to see anything that needs attention with 10 psi max. of pressure. Don't over do the air pressure in the crankcase. Post up your results! FWIW, I have seen 8-10 inches at the finish line (72-7,600 rpm) with my little 493 with the above mentioned stuff on it.
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494386
05/10/18 02:06 PM
05/10/18 02:06 PM
AndyF Offline
AndyF  Offline
Here you go. Billet valve covers seal up that area. Billet valley cover seals that up. Jesel belt drive seals up the front. Billet rail on the oil pan seals that up. Belt drive distributor allows the distributor hole to be tightly sealed. You get the idea.
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494387
05/10/18 02:07 PM
05/10/18 02:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Oil dipstick is an obvious leak. Have to plug it. Any caps or breathers in the valve covers as well. Leak test the engine to determine the condition of the ring package.
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494413
05/10/18 03:14 PM
05/10/18 03:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use a late model dipstick with the o-ring. Biggest leak area I found was at the head gasket/valley tray corners. Mine needed a little RTV at the very top corners of the head gasket. Air it up with some soapy water.
Doug
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494576
05/10/18 11:55 PM
05/10/18 11:55 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
The biggest area of leakage I found on my engine has always been rings. Having an alloy block doesn't help as it passes more oil when it's cold compared to when hot. But once warm I have 5" of vac when idling so that's reassuring the system has sealed up well.
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494665
05/11/18 09:21 AM
05/11/18 09:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
When my Dad's engine was on the Dyno the shop used a smoke machine to fill the crankcase and spot the leaks it really highlighted the areas that needed attention.
68 Barracuda Formula S 340
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494684
05/11/18 10:32 AM
05/11/18 10:32 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I use a vacuum pump and a air flow meter to measure leakage. The biggest that I have found are the crankshaft seals. In fact if you pressurize the engine with a smoke machine the rear seal doesn't seem to leak, pull 10 inches of vacuum and it's a different story.
Joe
Without Data, you’re just another guy with an opinion.
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494693
05/11/18 10:53 AM
05/11/18 10:53 AM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Biggest leak we found was at the valley pan corners. We will re-seal that, let the silicone cure and check for leaks again to make sure we have no issues.
Adriel Paradise
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494714
05/11/18 11:28 AM
05/11/18 11:28 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Seems to me that the crank seals can be expected to be big leakers simply by design. They're made to seal under pressure one way only.The solution in those areas would be something like an o-ring but you'd have to figure a way to keep them lubed. If you're running a vacuum pump, maybe install those seals backwards ?!?!?
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2494728
05/11/18 12:15 PM
05/11/18 12:15 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I ended up buying a cheap, rather crude, but effective smoke machine from Amazon that helped me a lot.
Biggest problems on my small block were the pan seals and the corners of the valley cover (R3/W9).
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2497899
05/19/18 04:17 PM
05/19/18 04:17 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Are you running with mufflers?
Abe Lincoln
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2497933
05/19/18 06:17 PM
05/19/18 06:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
40 years ago, Bill Jenkins put the rear main seal in his pro stock SBC engines backward for that reason.
Boffin Emeritus
Re: Sealing up engine for vacuum pump? [Re: Adrielp] #2498094
05/20/18 01:29 AM
05/20/18 01:29 AM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
I know a little about running a pump but , not going to bother posting cause I hate to argue
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
