To install a factory 90 degree adapter. The oil filter base plate is not used.
1. large round gasket glued to the block.
2. small thinner gasket under the bolt head
3. insert bolt into adapter
4. thicker small (cork?) gasket on bolt
5. install adapter to the angle you prefer and tighten.
Note: One time many years ago I could not get my adapter tight enough. I found the large bolt was too long and it was bottoming out. I ground it down some. Yours is probably fine but i just wanted you to be aware if you have that issue I had. Maybe it was a mismatch of parts
