87 kickdown #2494531
05/10/18 10:10 PM
05/10/18 10:10 PM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
A friend found a D350 in our local pick n pull and got me the upper bracket for a 4 barrel. Is the rod that goes to the transmission different from the 2 barrel? If so i gotta go get the rest of it!
Re: 87 kickdown [Re: Eggman] #2494551
05/10/18 10:48 PM
05/10/18 10:48 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
My bad.
Sorry.
Re: 87 kickdown [Re: Eggman] #2494663
05/11/18 08:32 AM
05/11/18 08:32 AM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
My truck is 2 barrel. He got me the bracket that bolts to the intake,but didn’t get the rod to the transmission. I was asking if the one I have is different.
Re: 87 kickdown [Re: Eggman] #2496327
05/15/18 10:18 AM
05/15/18 10:18 AM
scratchnfotraction Offline
2v = different intake bracket/rod/lever
4v = intake bracket is taller/rod is longer/ lever can be long or short depending in VB.
yes, go get all of it from carb slide rod/brar/intake bracket/1 piece down rod/ptk lever
if you are going to use the stock intake grab the q-jet that's on it as well.
this is the best way to convert over to 4v on the trucks.
q-jet to the ptk lever
should have a q-jet duel snorkel air breather on it also
may have the 360 center dump mannys with the long tube y-pipe with no cats or 1 cat mid stream after y-pipe. the long y-pipe is great for chopping into duels.
Re: 87 kickdown [Re: Eggman] #2496765
05/16/18 09:19 AM
05/16/18 09:19 AM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
Thanks,i went back and got it all. No air cleaner though. Dammit.
