Magnum swap questions installing a 4 speed behind it #2494503
05/10/18 08:31 PM
05/10/18 08:31 PM
ME
79machocharger Offline OP
ME
Dropped my magnum motor for my 70 satillite off to get the cam snout adaptor from Hughes installed on it so I can make the motor look correct appearance wise. I’ve also decided to go 4 speed behind it As well. I can’t find any one that has installed a 4 speed behind one. I check the pilot hole and it’s
To shallow. So I asked the machine shop to drill it out more and they said they should be able to no problem. There’s a 340 sitting right next to it in the shop to go by as far as depth.
I’m going to grab a timing chain cover off of a 318 I have kicking around and I’ll also use all the alt, power steering and pulleys off it as well. My only question is what will I use for a harmonic balancer now. Should I order a 360 la style harmonic balancer for it? Any recommendations?
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494509
05/10/18 09:11 PM
05/10/18 09:11 PM
5.2 or 5.9? I don't have an answer but this might get some feedback going.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494510
05/10/18 09:14 PM
05/10/18 09:14 PM
ME
ME
Sorry 5.9
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494513
05/10/18 09:25 PM
05/10/18 09:25 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think you will want to stick with the 5.9 Magnum flywheel and harmonic balancer so as not to affect your engine balance.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494514
05/10/18 09:26 PM
05/10/18 09:26 PM
Andrewh Offline
Andrewh  Offline
no I don't think you can use that.
someone will chime in that is sure, but it is neutrally balanced as I recall and the la 360 one is not.
Re: Magnum swap questions installing a 4 speed behind it [Re: Andrewh] #2494605
05/11/18 01:03 AM
05/11/18 01:03 AM
I copied this when Dog posted awhile back: 5.9 mag (360) external balance is different from a LA 360 external balance amount. 5.9 mag-use OE 5.9 flexplate/neutral converter. 5.9 Mag imbalance is in the flexplate. 360 LA imbalance is in the converter. 5.2 (318) mags are internally balanced as are all LA 318. 5.2/5.9/LA 360 use the same oil pan (sump locations vary of course-need different pickups) but use mag gasket with 5.2 & 5.9 pan & LA gasket with a 360 LA pan (on a mag block I am assuming he meant). this ain't helping you with a stick app & someone had posted something about some 5.9 mags haveing a different balance than other years of 5.9 LA (Dog will (likely) clarify when he comes to).
Re: Magnum swap questions installing a 4 speed behind it [Re: RapidRobert] #2494627
05/11/18 02:40 AM
05/11/18 02:40 AM
ME
ME
I might give these guys a call tomorrow about this
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494631
05/11/18 03:09 AM
05/11/18 03:09 AM
ME
ME
Drilling the 5.9 magnum out for the longer input shaft from a b body 4 speed ok?
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494632
05/11/18 03:10 AM
05/11/18 03:10 AM
ME
ME
I’ll look around and see if I can find a magnum flywheel.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494634
05/11/18 03:41 AM
05/11/18 03:41 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Should be fine drilling it, BUT have shop check for any oil passages that may be there, in other words dont go to deep. You could also just shorten the trans input shaft and install the magnum pilot bearing in hub of crank. You must use a magnum balancer.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494636
05/11/18 03:47 AM
05/11/18 03:47 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you need 130 tooth wheel for 10.5 cluth it was mopar p5249842, carb only not set up for crank sensor, I think mcleod makes one also. P4876056 for a pilot bearing, magnum style.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494637
05/11/18 04:03 AM
05/11/18 04:03 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
It was cheaper for me to have the crank balanced and use my old flywheel, I assume they are pulling the crank to drill it, if not I would run away. I disagree on the no big deal to drill it, was a big deal for me to get a billet hemi crank drilled and machined right but they may know something I dont. I would ask some questions. Here are the specs from a 360 magnum.
Piston 470
Pin 134
Rod small 225
Rod big 519
Rings 40
Rod bearing 47.6
Recip weight 869
Rotate weight 566.6
Weight per cylinder 1435.6
Bobweight 2002.2
These figures worked for my stock 360 mag 20 years ago, use at your own risk.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494638
05/11/18 04:12 AM
05/11/18 04:12 AM
ME
ME
Ok cool so cutting the input shaft down and using the magnum style bearing sounds good to me. I’ll go with a new magnum style balancer posted in the pic above. And now I just need the right magnum flywheel to bolt up behind it. I’ll look on eBay and see if I can find one.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494640
05/11/18 04:22 AM
05/11/18 04:22 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I dont think a truck flywheel will work with an aluminum bellhousing, dont remember exactly why, maybe 143 tooth vs 130, what do you have now 130?
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494642
05/11/18 04:32 AM
05/11/18 04:32 AM
ME
ME
Actually I’m not sure, I thought 143.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494643
05/11/18 04:35 AM
05/11/18 04:35 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Might work for you then.
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494644
05/11/18 04:36 AM
05/11/18 04:36 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
My aluminum bell was a 130, think 143 hits things in there, and starter wont fit.
Re: Magnum swap questions installing a 4 speed behind it [Re: 4406bbl] #2494645
05/11/18 04:41 AM
05/11/18 04:41 AM
ME
ME
Found two on eBay
One is 130 and the other was 143 out of a truck. The 130 was over $500. Really pricey!
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494646
05/11/18 04:43 AM
05/11/18 04:43 AM
ME
ME
They must of made two magnum style flywheels 130 and 143. I guess I should be looking for the 130?
Thanks for all the help
Re: Magnum swap questions installing a 4 speed behind it [Re: 79machocharger] #2494649
05/11/18 04:53 AM
05/11/18 04:53 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The 130 was never an assembly line piece, mopar did it for the crate motors. Crank sensor will not work so I hope you are using a carb. And yes its $$$.
