86 dually questions
#2492980
05/06/18 11:22 PM
05/06/18 11:22 PM
Posts: 416 Georgia
KingTuna
Georgia
Need some advice from the truck gurus. I have a guy close to me with an 86 dually that has mentioned trading with me for my 66 Fury. I love the old car, but I could get more use out of the truck.
It's an 86, single cab D350, long wheel base, 360 w 4 speed, has aluminum Alcoa wheels. Owner just replaced wheel cylinders and axle seals on rear. He also had a wiped cam lobe, and replaced it with a summit racing cam and lifters.
Anything prone on these trucks to being bad, and does this sound like a decent swap? I must admit I'm worried about smacking a deer and finding parts for the 66. Parts for a 2 year only body style ain't easy.
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
Re: 86 dually questions
[Re: KingTuna]
#2493070
05/07/18 03:44 AM
05/07/18 03:44 AM
RapidRobert
I ain't a truck guru but if I was in that position I would do like I'm sure you will do & that is evaluate it from head to toe.
