Page 1 of 3 1 2 3
. Help diagnose strange noise in drivetrain #249285
03/10/09 09:58 AM
03/10/09 09:58 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Just recently I have noticed a really awful sound coming from my roadrunner's drive train. All has been well and the car has been running perfectly for months. Just last week I noticed when I accelerate I get an awful noise like nuts and bolts falling off the car. I stopped and checked on the road and all was well. This has happened a few times as of late and I thought maybe the fan was loose and hitting the radiator as that is what it sounds like, but all is tight and no problems there. Yesterday it made that same noise right at start up too, but only for a second and went right away
The car runs perfect and drives fine so it's a very intermittent noise at best. I have crawled underneath and checked and retightend everything I can think of. I thought something might be loose and rattling around.
The noise is like rocks being thrown in the fan.
So any ideas on what to look for next?
Like I said the car operates perfectly except for once in awhile when it makes that ugly noise only on hard acceleration or at startup.
Thanks for any ideas.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249286
03/10/09 10:02 AM
03/10/09 10:02 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Check your torque converter bolts. Did you take down the driveshaft and check the u joints??
Re: . Help diagnose strange noise in drivetrain [Re: MoparforLife] #249287
03/10/09 10:14 AM
03/10/09 10:14 AM
No i have only visually checked the driveshaft and u-joints and all looked fine. I recently had a new 4-speed automatic installed though and i got all new u-joints and a new driveshart. I can pull the inspection cover and check the bolts on the torque convertor if that is what you mean.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249288
03/10/09 10:30 AM
03/10/09 10:30 AM
I've had cat. converters get noisy when they die, I wonder if mufflers do the same thing?
Re: . Help diagnose strange noise in drivetrain [Re: ] #249289
03/10/09 10:34 AM
03/10/09 10:34 AM
You know that crossed my mind too. I have the DYNOMAX mufflers that came with my TTI exhaust system. Think one of them came apart inside??
Re: . Help diagnose strange noise in drivetrain [Re: MoparforLife] #249290
03/10/09 10:36 AM
03/10/09 10:36 AM
Torque converter bolts for sure, had the same thing once! Make sure you loc-tite them down too or it will keep coming back!
Re: . Help diagnose strange noise in drivetrain #249291
03/10/09 10:43 AM
03/10/09 10:43 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
can you narrow it down a bit for the location? youve got the fan torque converter all the way back to the muffler so far. i need a smaller area.
so lets see, bad clutch fan? detonation??? hd mufflers come apart- rap on it and see if you hear a tinny sound). exhaust pipe rattling against the frame? torque converter bolts loos (although when they are loose, you usually have that noise all the time at the same conditions).
does the noise speed up as you accelerate? you said you have it under hard acceleration- does it always do it? open the windows and drive by those concrete barriers and theyll reflect the noise back at you (but its hard to tell where its coming from.
You need to get it on jackstand and see if you can get it to do it while standing still (rap on things, look around) and then start it and accellerate (be careful)
Re: . Help diagnose strange noise in drivetrain [Re: aarcuda] #249292
03/10/09 10:49 AM
03/10/09 10:49 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Really sounds like Torque converter bolts to me too.
Time to get the car in the air and "nut and bolt it" end to end. Throw a wrench or socket on everything under there. It was all put together in the past couple years, and with different parts. You may find only a few, or you may find a lot of stuff, but it's worth it for peace of mind.
Re: . Help diagnose strange noise in drivetrain [Re: aarcuda] #249293
03/10/09 10:51 AM
03/10/09 10:51 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
If you are running stock manifolds- check the "flapper" in the passenger side one. I have had 2 cars where they were loose- and made some crazy sounds that were initially hard to locate.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249294
03/10/09 10:52 AM
03/10/09 10:52 AM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Stu, you need to get rid of those DynoMax mufflers and get some of sunroofcuda's new mufflers.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: . Help diagnose strange noise in drivetrain [Re: 340727dart] #249295
03/10/09 11:23 AM
03/10/09 11:23 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Another vote for torque convertor bolts, but stu it is more likely that some pig who has found about Baconfest has sabotaged your car in an attempt to keep from the festivities........
Re: . Help diagnose strange noise in drivetrain [Re: 340727dart] #249296
03/10/09 11:25 AM
03/10/09 11:25 AM
Upper Midwest
Upper Midwest
Yes baffles do come loose in mufflers and can make a lot of rattling noises.
Re: . Help diagnose strange noise in drivetrain [Re: MoparforLife] #249297
03/10/09 12:01 PM
03/10/09 12:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Broken Motor Mount...When you hit the throttle the driver side of the engine will lift & the fan will hit the shroud.... Lift the hood, start the car, keep your foot on the brake, put the car in gear & watch te engine as you give it some gas... You'll know immediately...
Re: . Help diagnose strange noise in drivetrain [Re: 1_WILD_RT] #249298
03/10/09 07:14 PM
03/10/09 07:14 PM
Ok i took off the Torque Converer inspection plate and found these parts rattling around in there. What are they??
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249299
03/10/09 07:18 PM
03/10/09 07:18 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
That round piece looks like the torque converter hub. I have no idea about that other piece.
Re: . Help diagnose strange noise in drivetrain [Re: MidPenMopar] #249300
03/10/09 07:20 PM
03/10/09 07:20 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Muffler bearing.
Re: . Help diagnose strange noise in drivetrain [Re: 340727dart] #249301
03/10/09 07:21 PM
03/10/09 07:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like the nose off a Mini-starter...
Re: . Help diagnose strange noise in drivetrain [Re: 340727dart] #249302
03/10/09 07:22 PM
03/10/09 07:22 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Whatever it is, it doesn't look good!
Re: . Help diagnose strange noise in drivetrain [Re: 1_WILD_RT] #249303
03/10/09 07:22 PM
03/10/09 07:22 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
Hmm. Now that you mention it, that piece on the left looks like part of a starter.
Re: . Help diagnose strange noise in drivetrain [Re: 340727dart] #249304
03/10/09 07:33 PM
03/10/09 07:33 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Well, you have found the cause of the noise, now to FIX it!
Page 1 of 3 1 2 3
