Re: Engine condition Opinions?
[Re: ccdave]
#2497830
05/19/18 12:08 PM
05/19/18 12:08 PM
Posts: 12,028 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you change pistons, it really should be re-balanced. And new rod bolts and resizing the rods is also a very good idea. There goes a few hundred dollars.
How far out of spec are the cylinder bores? Keeping in mind that the budget is the prime motivator, why not just re-ring it?
If the cylinders aren't a train wreck, you might think about a hone job and throwing some new rings in along with new bearings and calling it good.
Way back when, we used to do that all the time. I remember knurling pistons that were way out of spec for the cylinders. It worked well in low speed applications. You can get several years out of a cheapy job like that if the pistons don't flop around in the cylinders too much. And of course, they make rings just for this.
It might be best to either do a full-on economy assembly or a full-on re-build. Not something in between.
Master, again and still
[Re: DaveRS23]
#2497840
05/19/18 12:27 PM
05/19/18 12:27 PM
Posts: 195 Coastal Maine
Mr onetwo
Coastal Maine
It might be best to either do a full-on economy assembly or a full-on re-build. Not something in between. Budget I just wanna drive my truck a bit this year!The guy said it was just inside .007 spec is .005 to .007 I guess.I would love to do exactly as you say Dave.I will call them Monday morning. i can save a bunch of money by using Enginetech bearings as opposed to Clevite 77...thoughts?
[Re: Mr onetwo]
#2497935
05/19/18 06:21 PM
05/19/18 06:21 PM
Posts: 4,206 New York
polyspheric
New York
Skip the EFI, put the money inside the engine.
Boffin Emeritus
[Re: Mr onetwo]
#2498010
05/19/18 10:03 PM
05/19/18 10:03 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It might be best to either do a full-on economy assembly or a full-on re-build. Not something in between. Budget I just wanna drive my truck a bit this year!The guy said it was just inside .007 spec is .005 to .007 I guess.I would love to do exactly as you say Dave.I will call them Monday morning. i can save a bunch of money by using Enginetech bearings as opposed to Clevite 77...thoughts? Good oil, proper clearances, and low RPM doesn't require premium parts to live.
[Re: Mr onetwo]
#2498124
05/20/18 08:13 AM
05/20/18 08:13 AM
Posts: 3,163 Md.
carnut68
Md.
As stated the 2266 piston is terrible. They will be at least.060 -.080 in the hole. With an iron open chamber head thats a bad combo. No compression no quench. It'll run but it won't be efficient. You should try to get a piston with a 2.060- 2.065 compression hgt. Get your short block together then pic your cam. Do it right or you may pay later. Ask me how I know..
America First!
[Re: Mr onetwo]
#2498173
05/20/18 12:09 PM
05/20/18 12:09 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That is certainly a mild cam. Why not just us a stock, original cam? There are a lot of them lying around and they have proven themselves to be very reliable.
[Re: DaveRS23]
#2498186
05/20/18 12:37 PM
05/20/18 12:37 PM
Mr onetwo
Coastal Maine
I am going to get the Summit SUM-6400 cam and lifter kit as it is better than stock and you can't beat the price at $117.My question is how should I install the cam for my application...straight up or advanced?Also, it is a cast crank motor...what should I do about balancing?I don't have the rods yet, but when they arrive I will weigh both new and old assemblies and post up the difference.Also any thoughts on what I should do about a distributor and the ignition timing.Thanks in advance for your help!
[Re: Mr onetwo]
#2500805
05/26/18 09:50 PM
05/26/18 09:50 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
[Re: Mr onetwo]
#2500961
05/27/18 11:47 AM
05/27/18 11:47 AM
Cab_Burge
Thank you Mr.Cab, any thoughts on balancing? I would have it done by a good shop There are two different weights involve in rotating assembly, the individual and total weights of each reciprocating and rotating parts and the rotational weights of the components, this is probably not the correct terms to describe what I mean but if you don't own or have access to a good automotive balancing machine have a good shop balance the rotating assembly for you
[Re: Mr onetwo]
#2506517
06/10/18 11:14 AM
06/10/18 11:14 AM
RapidRobert
cam bearings only need a 1/16" dia lube hole so if you have that much area left from how they clocked em you are fine but it would make me wonder about their meticulousness cuz that operation is a no brainer. any more than that is a waste of precious psi & the as produced cam bearing drilled hole is much bigger than 1/16" (the 2 that feed the heads-1/8" needed).
