Re: Using 2018 Demon tech to increase power in a classic car.
[Re: Kern Dog]
#2492435
05/05/18 02:05 PM
05/05/18 02:05 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Don't forget that the underhood temp is way higher than the outside ambient temps. Factor in heat off the radiator, coolers, engine, exhaust etc and the existing filter is sucking all that in. One of the reasons I'm going NASCAR style on mine and ducting it to the cowl. Pretty much any newer, at least since early 90's, vehicle is pulling air in through ducting that grabs outside cooler air. You are very correct in that we can learn technology from newer rides and apply that to our old stuff.
Carl Kessel
[Re: Kern Dog]
#2492438
05/05/18 02:20 PM
05/05/18 02:20 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
On a naturally aspirated engine The drawback would be that you are sucking air through a condensor, so, it would be like running with a plugged air filter. It would do more harm than good.
Mo' Farts
Moderated by "tbagger".
[Re: GoodysGotaCuda]
#2492441
05/05/18 02:30 PM
05/05/18 02:30 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I would be curious to see what modifications were done to the HVAC system to get that done. It takes a ton of capacity to cool that much air at those kinds of RPMs. I am not sure the benefits are worth the effort on a n/a application, just getting a nice ambient air charge will get you at least 40°+ reduction in IAT on a hot summer day. I don't believe it uses it under power, I think it is utilized off power to cool the liquid for the intercooler. You would be better off sourcing a fresh air source, if you did manage to do something with the AC you would have to overcome the loss of running the compressor (10-15HP?) before you gained a thing.
68 Barracuda Formula S 340
[Re: Kern Dog]
#2492442
05/05/18 02:31 PM
05/05/18 02:31 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
it could be a cheap way to add power C'mon Frankie... Get that s!!t out there where it can breathe...
[Re: Bad340fish]
#2492459
05/05/18 03:31 PM
05/05/18 03:31 PM
DaytonaTurbo
Manitoba, Canada
I think you're right. There's no free energy so any extra energy provided by cooling the inlet charge by the a/c compressor would be made back up by an extra load placed on the a/c compressor. My understanding is the a/c intercooling systems are designed to cool the liquid in an air to water intercooler between runs down the track when extra load on the a/c compressor doesn't matter. If you look at how many BTU/H an a/c system can cool, I think this is the only realistic application for this system. On a n/a maybe you could use it to cool fuel? Fresh air intake to the carb and sealing off it from outside air should be your first step IMO.
[Re: Kern Dog]
#2492624
05/06/18 12:39 AM
05/06/18 12:39 AM
Posts: 612 Nampa, ID
None2Slow
Nampa, ID
Heres a video that helps explain whats going on. https://youtu.be/wLOkr-hUnU4And for those that like to read... In order to make sure the Demon's intake receives air cool enough to make 840 supercharged horsepower, Dodge used the car's air-conditioning system to chill intake temps. How do they do it? It actually pretty simple. Instead of merely relying on the Demon's intercooler alone to cool air as it's pushed through the supercharger, Dodge engineers developed a passageway for the air-conditioning system to pass into the intercooler's closed loop, chilling the liquid coolant even further. This allows for cooler air temps, and therefore, more power. The only downside? The A/C won't pump cool air into the cabin if you set it to cool the engine. We think that's a fair trade-off for a sub 10-second quarter-mile time.
