Limitations of E Body Hemi oil pan ?
#2491938
05/04/18 01:04 PM
05/04/18 01:04 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I'm currently running an old Proform 7qt. pan that's seen some abuse over the last 25 years and I'm looking to replace it. I'm thinking about going to the E Body St Hemi pan for more ground clearance. Would this pan be suitable, capacity wise? I'm thinking it is, but looking for other input. I'm running low 11s at around 6400 through the lights.
72 Plymouth Roadrunner 11.08@123.25
Re: Limitations of E Body Hemi oil pan ?
[Re: Roughbird72]
#2491948
05/04/18 01:19 PM
05/04/18 01:19 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
You would be fine with going with this.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2491952
05/04/18 01:24 PM
05/04/18 01:24 PM
crabman173
crabman173
summit branded is exact same pan for just $95 their pick ups suck they are very very rusty inside ( china crap) so use stock pick up That pan should work perfect for you same pan as Mopar perf from Summit as a summit brand
[Re: Roughbird72]
#2491972
05/04/18 02:02 PM
05/04/18 02:02 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
I ran that pan in my old Duster with the pump gas 518 C.I. low deck stroker motor, it needed to be above the add mark at the 1/4 mile track to not see a small drop of oil pressure when I let off on the other end It would cross the finish line between 6500 and 7100 RPM depending on which tires where on the rear at 10.00 ET at 134.+ MPH No problems on the street ever with that pan or at the 1/8 mile tracks I use them now on every build I can
[Re: Roughbird72]
#2492100
05/04/18 05:24 PM
05/04/18 05:24 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
I used the Milodon one on my 68 Charger.
[Re: lewtot184]
#2492155
05/04/18 07:55 PM
05/04/18 07:55 PM
BradH
you folks are more generous in your positive comments about the 6qt pan than i'd be. Not entirely sure what you mean. However, if it's because of the minimal amount of oil control, that's why mine is set up as described HERE.
[Re: BradH]
#2492175
05/04/18 08:41 PM
05/04/18 08:41 PM
Roughbird72
Make sure it's their version of the Street Hemi pan 30761, not the lower-capacity standard pan 30760. The 30761 is $150.95 through Summit.
