"Death Wobble" in '67 a-body - think it is FIXED!
#2491150
05/02/18 10:38 PM
05/02/18 10:38 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
I have a completely rebuilt '67 barracuda. Ever since I put it together it always had an odd shimmy in the front end. It was never that bad, just something that I could never figure out. It would come and go randomly.
The car is "completely new", full rotisserie restoration, almost every part touched.
Setup: 1. manual steering, I installed and setup myself the 20:1 quick ratio gear box. 2. All new Moog (US) front end components 3. '73 (used, but restored) front disk brakes (and the 10.5" rear drums for big bolt pattern on the back). 4. Alignment done by me with a fasttracks unit. Aligned for maximum caster, I can't remember where I set the camber (1 deg?), and the toe at 1/16 (I think). 5. new rubber LCA bushing, Moog Rubber "problem solver" rubber bushings in the UCA (2x in each in opposing directions)
Car drives straight, but does have a lot of slop in the steering wheel (at least from 11 o'clock to 1 o'clock). Overall it handles well.
Sometimes if feels like the front end is moving to the right and left a little bit in some set frequency, moving faster you can "push through it" and then it stabilizes out.
I drove the car today, and it appeared a little worse, but it has been a while from the last time I drove it, so I don't know.
Anyway, I hit a large pot hole on the right side and it entered into what can best be described as the "death wobble" I see on the Jeeps, a violent back an forth on the steering wheel, but still tracked straight.
------- This is what found and it drives MUCH better!
Well I think I found out what it was... Should have been the first thing I should have checked!!!
The wheels were toed OUT, only slightly but but about a 1/16-1/8.
I toed them back in and it is MUCH better, need to get a real alignment now!
The steering box was definitely loose, which was a factor, or maybe a symptom, and it might never have been completely tight.
Pulled over, checked that everything was tight, tie rods are tight, upper lower ball joints appear tight (still on cotter pins), UCA bolts, LCA bolt, etc. Steering box appears tight to k-frame.
Everything in the suspension appears tight; limped it home, with no major issues, just some occasional left right osculation in the front end.
Any thought of what to look for?
Re: "Death Wobble" in '67 a-body
[Re: 6T6Cuda]
#2491191
05/02/18 11:36 PM
05/02/18 11:36 PM
Posts: 10,233 Someplace you aren't
SomeCarGuy
Check the tubes in k bar for broken welds. I’ve had those on cars I’ve redone. Fixed before driving, so no idea if it would cause your issue.
What is going on with box? You rebuilt it and it isn’t tighter than that? Adjustment maybe? Problem with coupler?
I want my fair share
[Re: ahy]
#2491193
05/02/18 11:40 PM
05/02/18 11:40 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Might be hard to do on the ground (ramps? or if you have access to a lift) but you might have someone "wiggle" the wheel between the 11 and 1 you mentioned and see if the linkage is moving up and down. If not, I would tighten the box up some.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: I_bleed_MOPAR]
#2491239
05/03/18 12:49 AM
05/03/18 12:49 AM
RapidRobert
As said, checkout/correct the box first (start with the coupler/shoes). then a good visual/checkout elsewhere since as you know something is loose/misadjusted/bad. Holler how it turns out/what it was.
[Re: 6T6Cuda]
#2491308
05/03/18 07:49 AM
05/03/18 07:49 AM
Posts: 5,951 ohio
ruderunner
ohio
I'd like a better description of the wheels and tires as well as balance method.
Don't overlook the rear suspension
Angry white pureblood male
[Re: 6T6Cuda]
#2491403
05/03/18 12:11 PM
05/03/18 12:11 PM
Posts: 1,269 Denver, CO
BigBlockGTS
Denver, CO
I have dealt with this on 4 wheel drives that had otherwise good suspension- bushings, tie rods, etc. The oscilating you describe, particularly after hitting a pot hole on one side is exactly what one of my trucks would do and you are correct- there is no driving through it.
Check the tightness of the wheel bearings- I know it sounds different or weird but I had just rebuilt my front end, just like you, and sometimes with all that fresh grease etc., you need to go back and retighten. I have a tendency from my drag racing days to set stuff up too loose.
I did that and the truck was perfect.
[Re: Paul_Fancsali]
#2491587
05/03/18 05:04 PM
05/03/18 05:04 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Try adjusting the centering valve in the steering box that did wonder for my old Plymouth with a ton of free play now minimal Follow the procedure in the FSM.
[Re: 6T6Cuda]
#2491616
05/03/18 06:08 PM
05/03/18 06:08 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
My hemi dart would go into the death wobble sometimes. couldn't figure it out at first. nothing damaged, went on alignment rack a few times.
I couldn't figure it out until it happened really bad, then when pulling into the driveway my oil pan scraped the ground where it never had before. the front end was riding lower. if you watch a drag car do a big wheel stand, when it comes down hard the front end shakes for second before the suspension recovers and lifts the car. in my case the torsion bars were weak and wouldn't lift the car out of it. If I hit a bump or on hard deceleration it would go into the shake.
This goes against normal thinking as it is a scary situation, but if it happens again hit the gas for a second and see if it lifts out of the shake. might want to check your ride height, and that your torsion bars still have enough spring in them to snap the car back up to its proper ride height.
might be a different issue in your case, but that is what I was up against.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
