Re: newbie starter instal question
[Re: plazomat]
#249094
03/10/09 12:20 AM
03/10/09 12:20 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
To remove the large stocker I'd say yes.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: plazomat]
#249097
03/11/09 11:32 PM
03/11/09 11:32 PM
Posts: 5,270 Missouri
MY340
Missouri
On my 73 Duster all I had to do was separate driver side tie rod and pitarm connection then swing center link out of the way.
Didn't have to loosen header to remove fullsize starter to replace with mini-starter.
Job takes about 1.5 hrs if linkage separates easily which it should with the right tools.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
