Tach wiring with msd tach output wire
#2490629
05/01/18 08:58 PM
05/01/18 08:58 PM
Posts: 1,179 clarks summit pa
73cuda340
clarks summit pa
Has anybody used the gray tach output wire from an msd box to hookup their tach, or do you just use a wire from the negative side of the coil? I'm hooking up the rallye dash in my car and I had the tach converted to work with an msd ignition and the label on the tach says to use the negative coil wire. Wouldn't the gray wire from the msd box be the same signal wire as the negative coil wire? I already have the msd wire behind the dash and I would rather use that if it'll work instead of having to run an additional wire through the firewall to the coil.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Tach wiring with msd tach output wire
[Re: 73cuda340]
#2490685
05/01/18 11:37 PM
05/01/18 11:37 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I used the gray wire from the msd box.
68 Charger R/T 440 auto
[Re: earlymopar]
#2491216
05/03/18 12:15 AM
05/03/18 12:15 AM
73cuda340
clarks summit pa
My car has the rallye dash with the stock internals converted to work with an msd ignition. I just ran a new wire to the coil just to be safe.
[Re: Dave Hall]
#2491389
05/03/18 11:47 AM
05/03/18 11:47 AM
73cuda340
clarks summit pa
If you are using an MSD ignition and your tach is calibrated for that use, use the MSD output. No wires other than the MSD coil wires to the coil. I have the tach wired to the coil now. Do you think there will be any issues wired this way? The guy who converted the tach knew I had an msd setup and he said to use the negative side of the coil.
[Re: Twostick]
#2491502
05/03/18 02:35 PM
05/03/18 02:35 PM
73cuda340
clarks summit pa
OK thanks. Good thing I didn't start the car.
