A-727 From 68 Pickup different than a car 727? #2489243
04/28/18 10:08 PM
04/28/18 10:08 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I scored a complete 318/727 that is from a 70k mile 1/2 ton truck....for a whopping $5 at a local auction.
There is a 1 inch hole in the top of the bell housing that looks factory. Anyone know what the purpose was for. Other than all the cable shift stuff, are these any different than a car A-727?
Chris
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489250
04/28/18 10:18 PM
04/28/18 10:18 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
That hole is used for checking and setting engine ignition timing when that trans is in a van.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489323
04/29/18 01:25 AM
04/29/18 01:25 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Check the governor weights and springs. They are different in a truck than a car. Truck one shifts way sooner.
Garth
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489345
04/29/18 02:07 AM
04/29/18 02:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Check the tail shaft housing. I had a trans that had a van or truck housing that the c-clip access plate was on the side of the housing instead of the bottom. That access plate would hit my trans tunnel and eat motor mounts and make a racket.
Bought the car that way, took me a year or so to figure it out.
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489354
04/29/18 02:20 AM
04/29/18 02:20 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I'll be sure to double check. The engine has 318-3 on it, appears to never been apart. Dated late 67, so 68 motor.
Would this be considered the 318-3 with the forged crank that I've always heard about?
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489644
04/29/18 07:24 PM
04/29/18 07:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A 1/2 ton 318 crank wouldn't be anything special. Is the -3 in the casting number? If so, its just a foundry index number.
The truck tail housing sometimes doesn't have the ears on the lower side for the console shift bracket. The side snap ring access plate didn't arrive until '72.
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489656
04/29/18 07:50 PM
04/29/18 07:50 PM
A727Tflite Offline
A727Tflite  Offline
A true 318-3 is a special truck engine with select components, hardened crank, and other items. They usually came in the cab and chassis trucks.
Not sure if you are referring to a casting number in the block or not- but there are distinct changes/additions to a true 318-3 truck engine.
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489675
04/29/18 08:58 PM
04/29/18 08:58 PM
MO
cdp Offline OP
cdp  Offline OP
MO
318-3 is cast into the block, I'm not 100% sure which size truck it came from. Being still has the cable attached, throttle brackets, etc, I'm assuming a 1/2 or 3/4 ton. I know that the 318 forged crank 318 time span is sketchy. Some say 71-back. Others, it ended in 68.
Transmission has the cast in bracket holes. It appears to be the same as a 70-340 transmission I have on hand. Truck tranny pan rail numbers: PK28293140 2234 build date (1967 and matches block cast date)
Something else I noticed, is the crossover pipe in front of the pan.
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2489766
04/29/18 11:45 PM
04/29/18 11:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I thought that the number after the engine size was how many bore cores were changed in the mold at the foundry.
Re: A-727 From 68 Pickup different than a car 727? [Re: justinp61] #2489782
04/30/18 12:36 AM
04/30/18 12:36 AM
that was my understanding of what that (- #) was.
Re: A-727 From 68 Pickup different than a car 727? [Re: RapidRobert] #2489988
04/30/18 02:27 PM
04/30/18 02:27 PM
dogdays Offline
dogdays  Offline
The people doing the casting didn't know in which vehicle the block would end up. So there's no way that a 318-3 engine would have anything cast onto it that signified that.
Your number is just a "dash number" which has to do with the casting process as mentioned above.
There are no magic dash numbers like some people think. With Mopar's spotty casting quality cylinder wall thickness, for example, can be all over the place. So if contemplating a high(er) dollar build, the first step should be checking the cylinder wall thickness.
I think you got a smoking deal! It's at least a good core. Given the toughness of the 727 it may be a bolt in and go part. The shift points are, as mentioned above, most likely at a lower rpm than a passenger car. Maybe John Kunkel will tell us.
R.
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2490010
04/30/18 03:03 PM
04/30/18 03:03 PM
A727Tflite Offline
A727Tflite  Offline
Some of you are confused and some of you are correct.
To clarify my post and only my post - since some of you have difficulty in understanding -
The 318 - III engine is unique in some ways as i outlined.
The cast in numbers do not relate to the engine model just like there were no differences between a 440 block cast for a station wagon versus an A12 car.
Re: A-727 From 68 Pickup different than a car 727? [Re: cdp] #2490095
04/30/18 06:53 PM
04/30/18 06:53 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
weren't most 318 motors forged cranks?
the 318 in my '77 powerwagon has a harmonic balancer on it that looks to be for a forged crank...
Re: A-727 From 68 Pickup different than a car 727? [Re: krautrock] #2490122
04/30/18 08:24 PM
04/30/18 08:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Forged or cast, the 318 was always internally balanced so the dampers aren't different for forged/cast.
There's conflicting info but some sources say the 318 cast crank first appeared in '67 or '68. shruggy
