Driveshaft collar issues. #2489563
04/29/18 04:23 PM
04/29/18 04:23 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
I'm going to monitor drive shaft RPM using the MSD Grid. Trouble is I don't appear to have any room to fit an 8 magnet collar on the pinion. I'm running a Dana 60 and there appears to be a metal dust plate there, and anyway, it's way to thin @ .200".
Has any used the slip yoke instead? I know it's gonna move but how far?
TIA up
Re: Driveshaft collar issues. [Re: Tig] #2489574
04/29/18 04:58 PM
04/29/18 04:58 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
.200" is almost 1/4" How is that too thin?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Driveshaft collar issues. [Re: Tig] #2489584
04/29/18 05:28 PM
04/29/18 05:28 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Have you seen the thread about using the park ring in the transmission as a wheel? Absolutely fabulous idea from “dizuster”.
Much easier to run wiring to, and a higher tooth count for low speed accuracy.
Re: Driveshaft collar issues. [Re: Tig] #2489586
04/29/18 05:32 PM
04/29/18 05:32 PM
the Netherlands
dutchrunner Offline
dutchrunner  Offline
the Netherlands
Strange has special yoke and collar. did my S60.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: Driveshaft collar issues. [Re: Tig] #2489600
04/29/18 06:09 PM
04/29/18 06:09 PM
est
huimerind Offline
huimerind  Offline
est
I made one. Not for dana, but it fits, without that dust plate.
Next time I would put it in transmission.
Park gear is perfect for that and cheap to do, sensor costs almost nothing.
Re: Driveshaft collar issues. [Re: Tig] #2489601
04/29/18 06:11 PM
04/29/18 06:11 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
DANA 60 YOKE RACEPAK STRANGE PN U1598 FOR MAGNETIC COLLAR
2 MAGNET COLLAR STRANGE U1617-2 OK OPTION
4 MAGNET COLLAR STRANGE U1617-4 BEST OPTION
Part numbers for the Strange parts.
Real Men shift for themselves
Re: Driveshaft collar issues. [Re: Tig] #2489606
04/29/18 06:16 PM
04/29/18 06:16 PM
AndyF Offline
AndyF  Offline
I went with the Strange pinion yoke which is designed for the collar. You can always fab your own solution but since I was starting from scratch I just purchased the complete solution.
Re: Driveshaft collar issues. [Re: Tig] #2489663
04/29/18 08:25 PM
04/29/18 08:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also had to change the yoke.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Driveshaft collar issues. [Re: hemi-itis] #2489765
04/29/18 11:32 PM
04/29/18 11:32 PM
davenport iowa
P
paul69cuda Offline
paul69cuda  Offline
P
davenport iowa
if you guys want go to motion race works they have 16 point collar wich works with the strange rear end yoke they used my d-60 yoke for design and i have one from them. these guys make odd ball parts for race cars they are sponcers of JASON DIGBY'S NASTY DART. check out the website or send them a message these guys are making some really cool parts to make things easier for the racer.MOTION RACE WORKS.COM
Re: Driveshaft collar issues. [Re: Tig] #2494343
05/10/18 12:10 PM
05/10/18 12:10 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Well I checked today to see how far the slip yoke would come out with the suspension at full droop. It barely moves, .040" max. Car has a lotta rise on it from launch but it looks like it won't make a difference. I'm guessing that it moves inwards more if the car were to go over bumps. Of course this now presents another problem, who makes a 1 11/16" 8 magnet collar ? confused
