Let's Talk Headers and Exhaust
#2488594
04/27/18 09:30 AM
04/27/18 09:30 AM
Posts: 195 Coastal Maine
Mr onetwo
Coastal Maine
Good day to all, I am planning the exhaust system for my '78 440 RC and need some opinions.I have purchased a really nice set of Doug Thorley Tri-Y headers for starters.I don't want to deal with header gasket leaks and don't mind spending the extra for Remflex graphite or Percy's Seal-4-Good aluminum ones.Which would you guys use on a normal street truck up to around 400 HP? Reliability is the top priority.Also..bolts or studs? I want this system to go into a single 3" after the transfer case.I think there is room for a Y pipe , H pipe to dual inlet muffler or an X-pipe type deal.I will be doing a fuel/air guage for tuning purposes so the h or x is better in my mind for O2 sensor location....thoughts on this? I also need advice on mufflers.I want a nice deep tone with no droning...maybe Flowmaster 50's...I don't know? ??? Finally, I think the Walker 45105 tailpipe from a 92-93 Cummins truck would be a cheap solution to work with the stock exhaust location...thoughts?This 440 will always be mild and I want nice street manners for it.I do want to put EFI on it eventually but will stick to the existing Holley 4175 that's on it for now.I have attached a photo of a good design I think.Thanks to all!
Re: Let's Talk Headers and Exhaust
[Re: Mr onetwo]
#2488727
04/27/18 05:21 PM
04/27/18 05:21 PM
Posts: 10,209 Someplace you aren't
SomeCarGuy
Can you get those headers for 2wd? I was looking recently for 77 d150 with 440 and didn’t see an offering from doug.
I want my fair share
[Re: SomeCarGuy]
#2488771
04/27/18 07:08 PM
04/27/18 07:08 PM
Mr onetwo
Coastal Maine
Can you get those headers for 2wd? I was looking recently for 77 d150 with 440 and didn’t see an offering from doug. They were used, but in perfect shape...ceramic coated.Unfortunately, you can't get them any more.I was very lucky to find them!
[Re: scratchnfotraction]
#2488772
04/27/18 07:09 PM
04/27/18 07:09 PM
Mr onetwo
Coastal Maine
oh I always add o2 in the header collector right next to the evac valve so it stays pluged in unless header is R&R
convenient would come to mind on this location me thinks wouldn't be more accurate (both banks mixed)to have it in the X-pipe?
[Re: Mr onetwo]
#2488901
04/28/18 12:29 AM
04/28/18 12:29 AM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Curious, gas tank in way the reason you're not going with dual exhaust?
I'm looking to do my exhaust too '79 Power Wagon
Facts are stubborn things.
[Re: Mr onetwo]
#2488902
04/28/18 12:30 AM
04/28/18 12:30 AM
SomeCarGuy
On the Muffler’s, I had a long thread going in the main tech section. Some good info there. Too bad the setbacks I’ve had have shelved the exhaust project.
[Re: larrymopar360]
#2488903
04/28/18 12:31 AM
04/28/18 12:31 AM
Mr onetwo
Coastal Maine
I'm looking to do my exhaust too '79 Power Wagon Yes, there isn't much room on the driver side
[Re: Mr onetwo]
#2488916
04/28/18 01:05 AM
04/28/18 01:05 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm looking to do my exhaust too '79 Power Wagon Yes, there isn't much room on the driver side Same here. I have dual tanks. Going to remove under bed tank I think, and just go with in cab tank. I really want dual exhausts.
[Re: Mr onetwo]
#2488925
04/28/18 01:24 AM
04/28/18 01:24 AM
Posts: 15,487 Florida
scratchnfotraction
convenient would come to mind on this location me thinks wouldn't be more accurate (both banks mixed)to have it in the X-pipe? if running a single 02 yes.
[Re: Mr onetwo]
#2488937
04/28/18 02:11 AM
04/28/18 02:11 AM
SomeCarGuy
On the topic, what’s the deal with all the 200 dollar SS headers on eBay for these trucks? Chinese knock offs of headman or hooker?
