New Floor Finishing - Suggestions #2488466
04/26/18 09:51 PM
04/26/18 09:51 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
Struggling with how to finish off the underside of my newly installed full floor pan in a B-Body.
I have no plans of prepping it for a body color finish and need to be able to spray, likely from a buzz bomb, with the car on jack stands. Undercoating, chassis black, etc.??
Thoughts?
Thanks-
Re: New Floor Finishing - Suggestions [Re: BPBP440] #2488494
04/26/18 11:42 PM
04/26/18 11:42 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Instead of low quality rattle can paint you can epoxy prime and paint the bottom with good car paint using a disposable Preval sprayer (around $8.00 +/-). The bottle will leak if you tilt it back too far so put something down to protect the floor if you try it.
If your after originality the correct color is whatever color gray/black primer the car was dipped in. That can be found on the firewall above the carpet line or behind a door panel about halfway up. If the car was undercoated then put more on over on over the top of the primer and paint.
Re: New Floor Finishing - Suggestions [Re: BPBP440] #2488670
04/27/18 12:46 PM
04/27/18 12:46 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
My 70 sport satellite was factory undercoated . . . so when I had it done, the front floor pans and trunk was painted black first, then I laid underneath the car, with it on jack stands, and used truck bed liner as under coat . . .
Re: New Floor Finishing - Suggestions [Re: a12rag] #2488687
04/27/18 01:41 PM
04/27/18 01:41 PM
dogdays Offline
dogdays  Offline
IMHO the epoxy primer is the best first step. It sticks, primes and seals. Whatever you put on over (under) it is mainly to protect the epoxy primer.
Bedliner would seem to be a decent topcoat.
R.
Re: New Floor Finishing - Suggestions [Re: dogdays] #2488861
04/27/18 11:03 PM
04/27/18 11:03 PM
IN
ahy Offline
ahy  Offline
IN
I used red Rustoleum primer then Rustoleum satin black. Has held up well. I brushed mine but red primer and satin black are available in rattle can also.
Re: New Floor Finishing - Suggestions [Re: ahy] #2489035
04/28/18 12:44 PM
04/28/18 12:44 PM
moparx Offline
moparx  Offline
plus, the rustoleum spray bombs work in any position. the only drawback is the time it takes to fully cure. sometime weeks depending on temperature conditions.
beer
