Has anyone ever done a mono leaf swap? #2487821
04/25/18 03:35 PM
04/25/18 03:35 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
My brother has been buying up a bunch of mono leaf spring sets. They are mostly for application in dirt track. But he can get me spring info for each.
I was considering the idea of changing my 92 5.2 Dakota over to a mono leaf setup if it would help with performance.
The truck is used as a car, not used to haul anything. But I do have an 8.75 rear diff, 4.30 gears, a 2200 stall, and a few mods to the 5.2 Magnum.
So its a fun truck, a bit of a sleeper, and I would like to find some more weight transfer and traction to the rear.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2487869
04/25/18 05:29 PM
04/25/18 05:29 PM
Locomotion Offline
Locomotion  Offline
I don't think that a mono-leaf would work well by itself. I personally wouldn't trust it. Leaf springs take a lot of abuse and they are usually used with Cal-Tracs. In that application, the springs only hold up the weight of the car. The forces generated by the launch are concentrated through the Cal-Trac bars.
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2487871
04/25/18 05:35 PM
04/25/18 05:35 PM
AndyF Offline
AndyF  Offline
Might work, kind of an obscure performance upgrade. I've seen guys with mono leaf setups, even some guys using fiberglass springs and stuff like that. You usually only see it where the rules are super restrictive so guys are trying everything they can to get a small weight advantage.
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2488331
04/26/18 04:28 PM
04/26/18 04:28 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
IMO, you will need a very strong shock or something like the Cal-Tracs bars that Myron mentioned. The mono leafs do not have the leaf to leaf resistance of a multi leaf spring so they can be bouncy.
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2492126
05/04/18 06:25 PM
05/04/18 06:25 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Thank you for the input guys!
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2492357
05/05/18 10:51 AM
05/05/18 10:51 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I have run monoleafs without caltracs on a stick car no less. They were ok for a while(about a year) then they rolled over and died. I didn't think they would work real well especially with the stick. They worked fine till they gave up
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2492413
05/05/18 01:22 PM
05/05/18 01:22 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
So how about a mono spring, and those Gabriel load handler coil over shocks that give you some extra weight leveling abilities?
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2492419
05/05/18 01:29 PM
05/05/18 01:29 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I have caltrac mono springs and traction bars on My 67 R/T....I ordered the 1" over and the car sits nice....I just need a better tire for traction. (no wheel hop)
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2492446
05/05/18 02:37 PM
05/05/18 02:37 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
What - do you think your Dakota is an old Firebird or something?
Re: Has anyone ever done a mono leaf swap? [Re: hp383] #2492460
05/05/18 03:37 PM
05/05/18 03:37 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I have considered an LS swap...
