How to idnetify a crank pulley for cast vs forged crank #2487822
04/25/18 03:35 PM
04/25/18 03:35 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Is there a quick way (e.g. bolt pattern, off set, etc...) to determine if a crank pulley is for a cast or forged crankshaft?
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2487860
04/25/18 05:08 PM
04/25/18 05:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
Not that I have ever heard of, Mopar changed the crank pulley bolt pattern in either 1971 or 1972 from non symmetrical to symmetrical on all the V 8 motors.
They didn't make and use different pulleys in the cast crank motors versus the forged steel crank motor shruggy scope That is probably due to cost and confusion on the assembly lines work
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2487862
04/25/18 05:12 PM
04/25/18 05:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it's for a BB there's some info here:
http://www.440source.com/dampers.htm
Elliptical weight is similar on some SB's.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2487870
04/25/18 05:32 PM
04/25/18 05:32 PM
AndyF Offline
AndyF  Offline
Your question doesn't make sense. Are you asking about the damper rather than the pulley?
Re: How to idnetify a crank pulley for cast vs forged crank [Re: AndyF] #2487923
04/25/18 07:28 PM
04/25/18 07:28 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Attached is a photo... are they the same for cast or forged crankshafts? Someone asked me once if a pulley I have was for a cast or forged crank. I was not sure how to distinguish, if there are different applications based on crankshaft. I know there is with and without AC or Power Steering.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2487946
04/25/18 08:34 PM
04/25/18 08:34 PM
Chicago
PurpleBeeper Offline
Chicago
Not that I am aware of other than casting numbers on the pulleys themselves, but I'm not sure that matters unless you are a "numbers matching" guy.
At least for RB motors, CAB is correct. In 1972, Mopar switched to a symmetrical bolt pattern on harmonic balancers (& pulley holes). Before that, there was one offset hole in both the balancer & the pulley.
As far as I know, the only mechanically important things are bolt pattern & pulley diameter & number of grooves/pullies on the part vs. your accessories (e.g. power steering, A/C, etc.). The pulley diameter would affect how fast your accessories turn (e.g. "overdrive" or "underdrive" your water pump).
The 440source list is a really good one.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488041
04/26/18 12:28 AM
04/26/18 12:28 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The bolt spacing is different. There is one bolt moved over on a forged crank pulley. You know how the bolt holes only line up one way? Then you,have to rotate the pulley to get all 6 to line up? Ever had that happen?
Then the early 70's they bolt on without any specific orientation because the bolt holes are spaced evenly? Somebody sells a crank pulley with an oblong hole to fit both balancers. Does this sound familiar yet?
I'll try to get a photo.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488073
04/26/18 01:49 AM
04/26/18 01:49 AM
Someone asked me once if a pulley I have was for a cast or forged crank. I was not sure how to distinguish, if there are different applications based on crankshaft. I know there is with and without AC or Power Brakes.
The person who ask you that question is not a Mopar knowledgeable person tsk The pulleys are different from some years to others, for instance in 1969 and later Mopar change the back spacing and diameter on the street Hemi pulleys shruggy1966 to 1968 are the same, 1969 and later are not. You can swap the upper and lowers as a set and make them work, you can't swap only one of them though scope
As far as power brakes the on Mopar cars pulleys have nothing to do with the brakes, power or non power shruggy in other words the pulleys on a standard steering car with power brakes are the same as if the car had regular brakes if they both have the same motors in them up
What does make a difference on the pulleys is power steering or power steering and air conditioning and the year and brand of the cars body stylescope
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488078
04/26/18 02:03 AM
04/26/18 02:03 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Let's not confuse the matter with the hemi, different animal. LOL
Re: How to idnetify a crank pulley for cast vs forged crank [Re: Cab_Burge] #2488138
04/26/18 09:57 AM
04/26/18 09:57 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Sorry, I meant to say Power Steering not Power Brakes. I corrected the post. Thank you for the feedback.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488211
04/26/18 12:41 PM
04/26/18 12:41 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Here are a couple of pics of the BB pulley in question.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488423
04/26/18 08:02 PM
04/26/18 08:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Examples
Forged balancer with a forged crank pulley, all bolts line up
Same forged crank balancer with a cast crank pulley, top bolt will not line up.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: NANKET] #2488548
04/27/18 01:49 AM
04/27/18 01:49 AM
Originally Posted By NANKET
Examples
WRONG tsk , you have a early pre 1972 pulley versus a 1972 and later pulley that both could have came on a forge steel crankshaft in either year motor shruggy
Trust us on this, your chasing absolute myths on this subject tsk
I have used the early pulleys on the later balancers by filing and elongating the odd ball hole to make it fit on the later forged steel crankshaft balancers up scope
Re: How to idnetify a crank pulley for cast vs forged crank [Re: NANKET] #2488562
04/27/18 04:04 AM
04/27/18 04:04 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
[/b]
Then the early 70's they bolt on without any specific orientation because the bolt holes are spaced evenly? [b]Somebody sells a crank pulley with an oblong hole to fit both balancers. Does this sound familiar yet?
WOW, file the hole, just like I said in my first post. Somebody sells that. I'm not chasing anything, I put up pictures to show the difference.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: NANKET] #2488696
04/27/18 02:17 PM
04/27/18 02:17 PM
I didn't see that your post was not part of vinnyd76 blush
Sorry up
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488708
04/27/18 03:17 PM
04/27/18 03:17 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
All is well! Too much info is good.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: NANKET] #2488806
04/27/18 08:20 PM
04/27/18 08:20 PM
dogdays Offline
dogdays  Offline
But Cab was right and you were wrong! You identified the PULLEY as "Description: Forged balancer with a forged crank pulley, all bolts line up"
The second picture showed the same forged crank balancer with in your description, a "cast crank pulley".
The point that Cab has repeatedly tried to make is there is no such thing as a "cast crank" or "forged crank" pulley.
There are pulleys and balancers made before the switchover date, and pulleys and balancers made after the switchover date.
Yes you can remedy the situation with a rattail file, no one argues that. But the pulley you are modifying was either made before or after the switchover date and that determines whether it has an offset hole or not.
Really, the only person to whom it would matter is a rabid restorer. But there are so many lies, errors and half-truths flying around the Mopar world that some of us try to snag them and hope to get them out of circulation.
R.
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2488847
04/27/18 10:29 PM
04/27/18 10:29 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
OK sounds good. Please tell use the "switchover date"
Re: How to idnetify a crank pulley for cast vs forged crank [Re: vinnyd76] #2489821
04/30/18 04:19 AM
04/30/18 04:19 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Pulley holes has nothing to do with cast or forged dampers, but just the year. I can fit a symmetrical hole pattern pulley on any damper as far is also symmetrical damper setup, no matter if casted or forged balancing damper.
BTDT.
The pulley setup and sizes changed allong the years due the diff engines setup and equipments itself. Some diff diameters considerations came out also to the rotation speed "upgrades" made allong the years to the diff miscelaneous parts for the engine ( alts, AC compressor, water pumps etc...)
