Re: Block heater, oil or water [Re: rowin4] #2486322
04/22/18 10:32 AM
04/22/18 10:32 AM
New York
polyspheric Offline
polyspheric  Offline
New York
True, but many have the ECM programmed to prevent WOT until water temperature is up.
Boffin Emeritus
Re: Block heater, oil or water [Re: rowin4] #2486328
04/22/18 10:43 AM
04/22/18 10:43 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
On my old 426 wedge Dyno mule there was a 20+ hp difference between cold oil and hot oil using 15/40. Warm the oil.
Re: Block heater, oil or water [Re: Cab_Burge] #2486365
04/22/18 12:34 PM
04/22/18 12:34 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Originally Posted By Cab_Burge
I don't have either but all the bucks up racers I know that do use electric heaters in their racers use them in the oil dry sump reservoir up Hot oil with cool water usually equals going faster also work
Oil takes longer to heat up so I would use one in the oil somewhere up twocents Heats rises, correct work grin
Actually, hot air rises. Heat goes where it's pointed. thumbs
Kevin
Re: Block heater, oil or water [Re: quickd100] #2486430
04/22/18 03:18 PM
04/22/18 03:18 PM
I did some oil temp testing on the first motor I dyno tested, I saw 8 HP gain from 130 F oil temps with straight 30 wt. oil to 170 F work
Later on I switch to 10w30Wt on a different engine and the same brand DTS dyno and saw 3 HP gain difference between 130F and 180 F shruggy
On the next motor I built and dyno tested I switch to 5W20WT and saw no HP differences between 70F and 220 F oil temps boogie work shruggy
Re: Block heater, oil or water [Re: rowin4] #2486556
04/22/18 09:26 PM
04/22/18 09:26 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Hot water rises, the "thermosyphon" effect allowed some small engines to work with a radiator above the jacket, but no pump.
Boffin Emeritus
Re: Block heater, oil or water [Re: rowin4] #2486607
04/22/18 11:17 PM
04/22/18 11:17 PM
ky
68roadrunner Offline
ky
my world screw in freeze plugs is the same thread as the brodix.
summit or jegs has adapters to screw in the block then 3/4 pipe threads screw into the adapters
Re: Block heater, oil or water [Re: 68roadrunner] #2487597
04/25/18 12:43 AM
04/25/18 12:43 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Are the KB threads the same as the World and Brodix?
Re: Block heater, oil or water [Re: Cab_Burge] #2487842
04/25/18 04:34 PM
04/25/18 04:34 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
On both of my cars I have 2 block heaters and an in pan oil heater wired to one plug. Also run a 180 thermostat. These are on alcohol. For the screw in plugs on my Indy block, I tapped them for 3/4 NPT and used the heaters from Jegs. On alcohol, heat is your friend. The hotter the air temp, the better the fuel is vaporized. My cars will start and run like a street car, even in 46 degree Dallas.
RIP
