E85 with Roots, What Compression? #2487506
04/24/18 09:35 PM
04/24/18 09:35 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I asked this of one of the local engine builders, and he wasn't sure.
The Methanol guys run +11:1 with a big blower....
What would you run on E85 and a roots blower? What would target boost be?
Re: E85 with Roots, What Compression? [Re: Dragula] #2487546
04/24/18 10:43 PM
04/24/18 10:43 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run more compression on race gas
Re: E85 with Roots, What Compression? [Re: Dragula] #2487573
04/24/18 11:37 PM
04/24/18 11:37 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I mulled over this question for a long time, read everything I could and talked to several people I respected. I settled on 11.5 in my 413 smallblock. E85 with a 6-71 and mechanical injection. Haven't run it yet but I'm getting very close.
I went with custom dished pistons and thick cometic gaskets. I went this way so that if I didn't like the blower setup it wouldn't cost a fortune to put thinner gaskets on it and have fair compression to run race gas.
Re: E85 with Roots, What Compression? [Re: Dragula] #2487578
04/24/18 11:47 PM
04/24/18 11:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think 10.5 would be good with E85 and it is not as forgiving as Meth1
Re: E85 with Roots, What Compression? [Re: Dragula] #2487617
04/25/18 01:55 AM
04/25/18 01:55 AM
I would determine how much boost you want at a specific RPM and then decide on how much mechanical compression to start with, regardless of the fuel type work twocents
Re: E85 with Roots, What Compression? [Re: Dragula] #2487620
04/25/18 02:05 AM
04/25/18 02:05 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The higher the CR,the smaller the tuning window........
I went 9:1 on gasoline.But I still street drive.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: E85 with Roots, What Compression? [Re: Blucuda413] #2487661
04/25/18 08:02 AM
04/25/18 08:02 AM
Dragula Offline OP
Dragula  Offline OP
That's what I was thinking. If I do somthing different this year with the G3 parts I have been picking up, I was looking at a 671HH and E85 with 2-carbs....11.5:1 I figured would be a good starting point but can't find any info on anyone who has done it...Most are running either straight Methanol 14-71 hi helix or a street car on gas.
This would be race only, but I wanted to see if there was any difference between the Methanol setup and E85...I was also wondering how high can the boost be pushed....Figured, why limit it like a street engine...its alcohol right....
Re: E85 with Roots, What Compression? [Re: Dragula] #2487711
04/25/18 11:16 AM
04/25/18 11:16 AM
New York
polyspheric Offline
polyspheric  Offline
New York
If you can control the spark, 20 psi is fine.
You haven't said what the blower is capable of - its efficiency range. "Roots" covers a lot of sizes and designs.
Boffin Emeritus
Re: E85 with Roots, What Compression? [Re: Dragula] #2487794
04/25/18 02:34 PM
04/25/18 02:34 PM
texas
thewolf1970 Offline
thewolf1970  Offline
texas
You can run 11.5 to 12.5 mark sullens builds a great e-85 carb or mechanical injection from kinsler have them flow a system. I have seen 40lbs of boost with e-85 you will love it.
Re: E85 with Roots, What Compression? [Re: Dragula] #2487865
04/25/18 05:20 PM
04/25/18 05:20 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
^^^ Yep go ahead and do that.
Re: E85 with Roots, What Compression? [Re: Dragula] #2487874
04/25/18 05:45 PM
04/25/18 05:45 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
If its race only, why bother with carbs? If it is strictly a race engine, then put a bug catcher on it. Cost wise, a pair of new E85 blower carbs vs. a good used bug catcher setup might not be that far apart.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: E85 with Roots, What Compression? [Re: DusterDave] #2487933
04/25/18 08:01 PM
04/25/18 08:01 PM
Dragula Offline OP
Dragula  Offline OP
I think it was his carbs on my buddys E85 440 with 671, and man it runs hard! Not to mention it has a nice clean idle...
As you know, I have had a Bug Catcher system. To be legal I have to run carbs or mechanical FI....I am not one for all the issues those guys have with MFI and there are no manners to it either. We will see what this season nets us...The Big Hemi is back together, and I have one last issue I need to fix, but its ready to run. It will be for sale, and I am switchiing....Its funny how many guys told me so far to put a Chevy in it.
Re: E85 with Roots, What Compression? [Re: Dragula] #2487994
04/25/18 10:23 PM
04/25/18 10:23 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
What are you looking to make hp wise?1600?That would take some big carbs.
Re: E85 with Roots, What Compression? [Re: Dragula] #2488000
04/25/18 10:38 PM
04/25/18 10:38 PM
NC
BaldwinCarbs Offline
NC
we can get these up to 1600 cfm
1750 cfm with a little extra shaft and booster work
Re: E85 with Roots, What Compression? [Re: Dragula] #2488002
04/25/18 10:40 PM
04/25/18 10:40 PM
NC
NC
top view
Re: E85 with Roots, What Compression? [Re: Dragula] #2488027
04/26/18 12:00 AM
04/26/18 12:00 AM
Superfreak
Superfreak
Re: E85 with Roots, What Compression? [Re: Dragula] #2488225
04/26/18 01:06 PM
04/26/18 01:06 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yeah, how much are those bad boys.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: E85 with Roots, What Compression? [Re: 6PKRTSE] #2488232
04/26/18 01:19 PM
04/26/18 01:19 PM
NC
NC
$1,500
Re: E85 with Roots, What Compression? [Re: BaldwinCarbs] #2488236
04/26/18 01:24 PM
04/26/18 01:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I too will be testing a twin for my Dart here soon and if it performs as well as the claims, I will be selling these for Get-M Garage just like Mr. Baldwin.............. beer
Re: E85 with Roots, What Compression? [Re: Thumperdart] #2488305
04/26/18 03:20 PM
04/26/18 03:20 PM
NC
NC
