Re: E85 with Roots, What Compression?
[Re: Dragula]
#2487620
04/25/18 02:05 AM
04/25/18 02:05 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
The higher the CR,the smaller the tuning window........ I went 9:1 on gasoline.But I still street drive.
[Re: Blucuda413]
#2487661
04/25/18 08:02 AM
04/25/18 08:02 AM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
I mulled over this question for a long time, read everything I could and talked to several people I respected. I settled on 11.5 in my 413 smallblock. E85 with a 6-71 and mechanical injection. Haven't run it yet but I'm getting very close.
I went with custom dished pistons and thick cometic gaskets. I went this way so that if I didn't like the blower setup it wouldn't cost a fortune to put thinner gaskets on it and have fair compression to run race gas. That's what I was thinking. If I do somthing different this year with the G3 parts I have been picking up, I was looking at a 671HH and E85 with 2-carbs....11.5:1 I figured would be a good starting point but can't find any info on anyone who has done it...Most are running either straight Methanol 14-71 hi helix or a street car on gas. This would be race only, but I wanted to see if there was any difference between the Methanol setup and E85...I was also wondering how high can the boost be pushed....Figured, why limit it like a street engine...its alcohol right....
[Re: Dragula]
#2487711
04/25/18 11:16 AM
04/25/18 11:16 AM
Posts: 4,205 New York
polyspheric
New York
If you can control the spark, 20 psi is fine. You haven't said what the blower is capable of - its efficiency range. "Roots" covers a lot of sizes and designs.
Boffin Emeritus
[Re: Dragula]
#2487874
04/25/18 05:45 PM
04/25/18 05:45 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I went with custom dished pistons and thick cometic gaskets. I went this way so that if I didn't like the blower setup it wouldn't cost a fortune to put thinner gaskets on it and have fair compression to run race gas. That's what I was thinking. If I do somthing different this year with the G3 parts I have been picking up, I was looking at a 671HH and E85 with 2-carbs....11.5:1 I figured would be a good starting point but can't find any info on anyone who has done it...Most are running either straight Methanol 14-71 hi helix or a street car on gas. This would be race only, but I wanted to see if there was any difference between the Methanol setup and E85...I was also wondering how high can the boost be pushed....Figured, why limit it like a street engine...its alcohol right.... If its race only, why bother with carbs? If it is strictly a race engine, then put a bug catcher on it. Cost wise, a pair of new E85 blower carbs vs. a good used bug catcher setup might not be that far apart.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#2487933
04/25/18 08:01 PM
04/25/18 08:01 PM
Dragula
You can run 11.5 to 12.5 mark sullens builds a great e-85 carb or mechanical injection from kinsler have them flow a system. I have seen 40lbs of boost with e-85 you will love it. I think it was his carbs on my buddys E85 440 with 671, and man it runs hard! Not to mention it has a nice clean idle... I mulled over this question for a long time, read everything I could and talked to several people I respected. I settled on 11.5 in my 413 smallblock. E85 with a 6-71 and mechanical injection. Haven't run it yet but I'm getting very close.
I went with custom dished pistons and thick cometic gaskets. I went this way so that if I didn't like the blower setup it wouldn't cost a fortune to put thinner gaskets on it and have fair compression to run race gas. That's what I was thinking. If I do somthing different this year with the G3 parts I have been picking up, I was looking at a 671HH and E85 with 2-carbs....11.5:1 I figured would be a good starting point but can't find any info on anyone who has done it...Most are running either straight Methanol 14-71 hi helix or a street car on gas. This would be race only, but I wanted to see if there was any difference between the Methanol setup and E85...I was also wondering how high can the boost be pushed....Figured, why limit it like a street engine...its alcohol right.... If its race only, why bother with carbs? If it is strictly a race engine, then put a bug catcher on it. Cost wise, a pair of new E85 blower carbs vs. a good used bug catcher setup might not be that far apart. As you know, I have had a Bug Catcher system. To be legal I have to run carbs or mechanical FI....I am not one for all the issues those guys have with MFI and there are no manners to it either. We will see what this season nets us...The Big Hemi is back together, and I have one last issue I need to fix, but its ready to run. It will be for sale, and I am switchiing....Its funny how many guys told me so far to put a Chevy in it.
[Re: Dragula]
#2488002
04/25/18 10:40 PM
04/25/18 10:40 PM
Posts: 24 NC
BaldwinCarbs
NC
[Re: Dragula]
#2488027
04/26/18 12:00 AM
04/26/18 12:00 AM
Superfreak
Superfreak
[Re: Dragula]
#2488225
04/26/18 01:06 PM
04/26/18 01:06 PM
Posts: 4,539 Motor City
6PKRTSE
Motor City
Yeah, how much are those bad boys.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2488232
04/26/18 01:19 PM
04/26/18 01:19 PM
Posts: 24 NC
BaldwinCarbs
NC
