Existing firewall hole for wires, E-body #2487552
04/24/18 10:51 PM
04/24/18 10:51 PM
BDW Offline OP
BDW  Offline OP
I want to run the controller cable for my Fitech through the firewall so I can easily hook up the hand held when needed.
Anyone have a good existing hole?
If not, where's a good spot to drill to avoid issues?
70 Challenger
Thx
Re: Existing firewall hole for wires, E-body [Re: BDW] #2487619
04/25/18 02:02 AM
04/25/18 02:02 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
on my cuda i ran some wires thrugh the plastic spikes that hold the under dash insulating pad on place .
had to clip off the tip so the wire could be feed through the plastic spike .
Re: Existing firewall hole for wires, E-body [Re: BDW] #2487689
04/25/18 10:19 AM
04/25/18 10:19 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
On my 69 road runner, I drilled out the hole where the air grabber cable went. I ran the MSD box wires through a grommet on that hole and mounted box under the dash. There are two dimples on the fire wall just below the cowl panel seam on the passenger side on e-bodies (at least 70 and 71). You could drill out one of those holes with a step drill. On the inside of the car, it should come out just above the heater box. Unless you are already running a shaker then one of the dimples will be already drilled and used for shaker cable.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
