Cuda leaf spring height stock, +1" #2486645
04/23/18 12:57 AM
04/23/18 12:57 AM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anybody have any pictures from the side of their cuda with new springs and which height they are? I'm looking into getting new springs and cant decide between the stock height and the +1"
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Cuda leaf spring height stock, +1" [Re: 73cuda340] #2486777
04/23/18 12:34 PM
04/23/18 12:34 PM
No pics but quite a few individuals have posted that +1 worked/looked good.
Re: Cuda leaf spring height stock, +1" [Re: 73cuda340] #2486780
04/23/18 12:42 PM
04/23/18 12:42 PM
an8sec70cuda Offline
Stock ride height Calvert mono springs w/ 295-65 drag radials.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cuda leaf spring height stock, +1" [Re: an8sec70cuda] #2486784
04/23/18 12:44 PM
04/23/18 12:44 PM
This was w/ a 275-60 rear tire and the stock height springs.
+1" would look too tall in my opinion.
I tried 1" lower springs at first (years ago), but it sat too low...Calvert swapped em out no charge.
CHIP
Re: Cuda leaf spring height stock, +1" [Re: 73cuda340] #2486829
04/23/18 02:17 PM
04/23/18 02:17 PM
central il.
second 70 Online content
second 70  Online Content
central il.
Stock ride height Calvert split mono w/28 x 11.5x 15 ET Street R bias ply
Re: Cuda leaf spring height stock, +1" [Re: second 70] #2486854
04/23/18 03:21 PM
04/23/18 03:21 PM
This is w/ a 29.5 x 10.5 ET Drag slick.
CHIP
Re: Cuda leaf spring height stock, +1" [Re: an8sec70cuda] #2487251
04/24/18 01:39 PM
04/24/18 01:39 PM
central il.
central il.
275/60/15 ET Drag radial with stock height split mono and Cal tracs
E60/15 Goodyear factory springs
91293AB4-2C55-4BE3-B615-043241700D24.jpg!Bg-e3z!BWk~$(KGrHqEOKisEryPK(ZvEBLHJ(9,nSw~~_3.jpg
Re: Cuda leaf spring height stock, +1" [Re: second 70] #2487791
04/25/18 02:27 PM
04/25/18 02:27 PM
clarks summit pa
clarks summit pa
Thanks for all the pictures. Does anybody have a +1" spring set for comparison?
