7500 rpm during the run, 7800 rpm limiter.
The crank pulley that may work for me is 5.3 inch diameter, so i need a reasonably priced alternater and pulley combo, a one wire if possible. Space MAY be an issue, so if there are multiple choices smaller is better.
I have mechanical fuel injection on alkys, the only draw for the most part is ignition, electronics, waterpump (mezuire) and a fair amount of cranking to get fuel back in the lines each time i move in the staging lanes.
Also battery recomendations, agm type to save a little weight over the 43 lb optima i run now.
Edited by gregsdart (04/24/18 06:27 AM)
GREG
Educated at SHK U
Measure with yardstick
mark with chalk
cut with torch!
528 cubic inch alky injected 440-1 wedge, 3055 race weight.
8.779 at 153.16 mph. 1.289 60 ft. density altitude 1617 feet. Best 60 ft 1.24
