Clutch Fan in Big Block Dart #2486573
04/22/18 10:14 PM
04/22/18 10:14 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
At this point I'm guessing Ma Mopar never offered a clutch fan in a bigblock Dart. Tried installing one, no way no how.
Abe Lincoln
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2486580
04/22/18 10:24 PM
04/22/18 10:24 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Okay.
Re: Clutch Fan in Big Block Dart [Re: Kern Dog] #2486586
04/22/18 10:42 PM
04/22/18 10:42 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
There is such little room in there, can't see how that could ever fit.
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2486728
04/23/18 09:31 AM
04/23/18 09:31 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
According the the Hayden catalog part number 1707 is the correct part for a big block Dart. The height is 3.59 inches. Hayden part 2947 is listed with a total height of of 2.71 inches.
http://www.haydenauto.com/online%20catalogs-ecatalog/content.aspx#
Re: Clutch Fan in Big Block Dart [Re: TooMany62s] #2486734
04/23/18 09:52 AM
04/23/18 09:52 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes there were clutch fans for big block A-Body's, no you cannot find a correct one. The normal non clutch fan has a .70 spacer which is equally hard to find.
JB Rhinehart, Realist
A-Body's RULE!
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2486766
04/23/18 12:21 PM
04/23/18 12:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Isn't there a short one for a Jaguar application?
The "direct-drive" fan on mine is actually too efficient at speed; thinking about getting another with fewer blades (car is not a resto), or a clutch style.
Re: Clutch Fan in Big Block Dart [Re: Rhinodart] #2486802
04/23/18 01:18 PM
04/23/18 01:18 PM
Mesa, Arizona
Mesa, Arizona
Thanks. Okay, have to ask, anyone with a bigblock Abody running a Hayden clutch fan?
Moving the rad is not an option.
Abe Lincoln
Re: Clutch Fan in Big Block Dart [Re: Rhinodart] #2486849
04/23/18 03:09 PM
04/23/18 03:09 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I was on a hunt last year for this spacer as I thought I got one years ago, but could not locate in my stash. After looking at what seemed like a few hundred at Carlisle, finally found.
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2486903
04/23/18 05:22 PM
04/23/18 05:22 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I have 2 big block a bodies. One that I made a D.C. Style k frame, that one has the Hayden clutch and fan, the jaguar clutch I think. The other has Schumacher mounts and no way the clutch will fit. something weird going on there. That clutch fan works great though.
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2486911
04/23/18 05:37 PM
04/23/18 05:37 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
I used the mopar performance clutch with the original fan in 69 M code Cuda with factory spacer
edit Sorry got mixed up with my small block the M code was solid mounted
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Clutch Fan in Big Block Dart [Re: topside] #2486924
04/23/18 06:21 PM
04/23/18 06:21 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
The Jaguar part will work but the 2947 is a better option. Jags had a plastic fan. The 2947 is designed to replace the original Mopar part. I think the 2947 is designed specifically for the '62 - '65 applications that had very little water pump to radiator clearance.
Re: Clutch Fan in Big Block Dart [Re: TooMany62s] #2486957
04/23/18 08:17 PM
04/23/18 08:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The Jag part is what I run on my '63. Works perfect, but I still had to move the tank saddles rearward on my stock radiator 1/2".
'63 Dodge 330
11.19 @ 121 mph
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2486969
04/23/18 08:54 PM
04/23/18 08:54 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I'll take a look at the number I'm running. I'm also using the Hayden fan. I think its aluminum.
Re: Clutch Fan in Big Block Dart [Re: dart4forte] #2487090
04/24/18 01:50 AM
04/24/18 01:50 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
$135 Spal 16 inch fan will cure all problems!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
