Rear brake line bracket.
#2486089
04/21/18 03:03 PM
04/21/18 03:03 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
After pulling this 69 Charger apart 12 years ago I am finally staring the reassembly. I have hundreds of pictures but for some reason none of this area. I just need to see which way the bracket went and how the steel line went to the left frame rail. Any pics would be great. Thanks.
Re: Rear brake line bracket.
[Re: NANKET]
#2486603
04/22/18 11:12 PM
04/22/18 11:12 PM
NITROUSN
That make more sense. I am attaching it to a bracket that is welded to the body floor and has a weld nut. I also see your e-brake cable and am wondering if that attaches to the body bracket that I thought the line bracket went to. Do you by some chance have a pic of the right e-brake cable routing?
[Re: NANKET]
#2486615
04/22/18 11:33 PM
04/22/18 11:33 PM
NITROUSN
Here is a 10 year old photo when I welded the Hemi pinion snubber plate in. I circled in red where I thought it should go. After looking at your photo I see where mine needs to go circled in green. Thanks for the help.
