Page 3 of 3 1 2 3
Re: Quarter Mile time for 1971 440+6 Roadrunner [Re: markshemiworld] #2486006
04/21/18 11:07 AM
04/21/18 11:07 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
I think alot of the disparity in the quarter mile numbers come down to two things. #1 the particular motor, most off the assembly line weren't within 1 point of advertised compression, the set of heads,(valve job and port alinement. The cams installed centerline. The distributor setup.
The stars could aline correctly and you had a real firebreather or you could get a dog.
#2 the driver, most didn't know how to launch a car with limited traction.
Re: Quarter Mile time for 1971 440+6 Roadrunner [Re: quickd100] #2486320
04/22/18 09:46 AM
04/22/18 09:46 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
When will this car actually go down the track?
Re: Quarter Mile time for 1971 440+6 Roadrunner [Re: markshemiworld] #2486329
04/22/18 10:44 AM
04/22/18 10:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the xe262 under cams the engine. 4.10's way over gear. 10.5:1 will never run on pump gas. I had a 9.3:1 engine with a 268/276 comp magnum replacement and it blew 195psi; really too high for reliable pump gas operation. i'd re-think the combo.
Re: Quarter Mile time for 1971 440+6 Roadrunner [Re: markshemiworld] #2486337
04/22/18 11:20 AM
04/22/18 11:20 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
it has 3.23 gear right now if i remember reading correctly, run the car down the track with those gears.
Re: Quarter Mile time for 1971 440+6 Roadrunner [Re: markshemiworld] #2486348
04/22/18 11:55 AM
04/22/18 11:55 AM
WA 98043
thecarfarmer Offline
WA 98043
Originally Posted By markshemiworld
I’m seeking some opinions on what y’all think a 1971 Roadrunner with these options would run in a quarter mile:
440 six pack
Bored 30 over
10.5 to 1 compression
Aluminum H Beam Rods
Forged Crank
Forged Pistons
Stock 906 heads with 3 angle valve job
Comp Cams Extreme Energy XE262H
Stock Holley Carbs with larger jets
Factory Electronic Ignition
Stock Manifolds
2.5” exhaust with Flowmaster 40 Series
TCI Streetfighter 727 with 2400 stall converter
8 3/4 with 4.10 rear gears
275/65/15 BF Goodrich Radial T/A’s on the back with Rallye Wheels
Car has power steering and power brakes and a Sanden A/C compressor. Car also has stock airgrabber hood with K&N air filter. Thanks ahead of time for your answers!
Man, I don't know how many miles I rode (and occasionally drove) in my buddy's '71 Sport Satellite in the '80's... Your post brought up a lot of memories!
Honest answer to the question, about fifteen flat after a bit of practice. With sharp tuning and lots of seat time, somewhere in the fourteens in decent conditions.
Real world performance for an OG musclecar...
If you're still planning/buying... I'd consider more cam, maybe a little less CR. Especially with a craptacular stock 906 open combustion chamber - prone to ping.
That cam you mention would be a good street cam for a 8:1 318, IMO you would leave a LOT on the table running a tiny cam with 440". More duration would help with moving that torque curve to the right (4.10's will be very short with that 262 cam).
"But what about low end torque?"
What'cha going to do with all that low end torque from a big block? Hook up on those T/A's? Puh-leeeeze. Yeah, guys *have* got cars to launch on hard tires, but often with light torsion bars,shocks, etc... you know, all the stuff that makes a car a turd to drive on the street. And you mentioned T bars, AC, PS, iron manifolds, etc. This is probably a super nice car to roll in. And the very things that make it so good for that work against ya' at the track...
If it's already built... put some 2.54's in it and be the burnout KING! All joking aside, I would think seriously about keeping the 3.23 gears.
Oh, and like was mentioned by others, might wanna check that cranking pressure... octane may be an issue.
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Page 3 of 3 1 2 3
