Can anyone identify what this intake manifold? #2485973
04/21/18 09:50 AM
04/21/18 09:50 AM
McCandlessboy Offline OP
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2485979
04/21/18 10:04 AM
04/21/18 10:04 AM
jersey
Spaceman Spiff Offline
jersey
Bolt pattern looks like a dodge red ram.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Can anyone identify what this intake manifold? [Re: Spaceman Spiff] #2486029
04/21/18 12:37 PM
04/21/18 12:37 PM
that is a strange one for sure
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2486035
04/21/18 12:52 PM
04/21/18 12:52 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
I believe it is an aftermarket intake for the '53-'54 Chrysler 331 hemi. The bolt pattern is the same and it has the water outlets in the proper location. The pre-1955 early hemis had a "wet" intake with the thermostat housing as part of the intake. The later hemis(late '54-'58)had a crossover manifold that held the thermostat and bolted to water exits on the front of each head. This one has the water outlets in the same location as the early "pre-'55" heads. It's a very unique manifold and probably worth $$$ to an early hemi enthusiast.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Can anyone identify what this intake manifold? [Re: Centerline] #2486075
04/21/18 02:32 PM
04/21/18 02:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
does the base have any similarities to the fuel injection early HEMI manifolds? shruggy & an adapter to carburate it?
Re: Can anyone identify what this intake manifold? [Re: 6bblgt] #2486150
04/21/18 06:09 PM
04/21/18 06:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Almost looks like an early attempt at a Modman intake like the one Indy sells shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2486194
04/21/18 09:57 PM
04/21/18 09:57 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
With two water outlets,may possibly be a marine intake,part number looks to be 1562843,puts it around 1954.
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2486325
04/22/18 10:38 AM
04/22/18 10:38 AM
I've posted on multiple message boards and social medial platforms. The consensus is, that nobody knows haha. It's a cool piece that hopefully one day we can track down exactly what it was used for.
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2486389
04/22/18 01:12 PM
04/22/18 01:12 PM
moparx Offline
moparx  Offline
if nothing else, great "garage art" ! up
beer
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2486407
04/22/18 02:23 PM
04/22/18 02:23 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
I would call or e mail HotHeads the early hemi guys I think in the Carolinas or georga. They specialize in those engines. I also was thinking marine or maybe a stationary pump or industrial application. Its a nice piece.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Can anyone identify what this intake manifold? [Re: yella71] #2486925
04/23/18 06:23 PM
04/23/18 06:23 PM
dogdays Offline
dogdays  Offline
It's for early Firepower Chrysler. Bolts go 1-2-2-2-1 with the center 2 and the outer ones closer to the centerline of the intake.
The Desoto has them pretty much all in a row.
The Red Ram is backwards from the Firepower and the center two are farther away from the intake centerline.
It doesn't look factory to me, but the part number is, except for the "E". Is it cast iron or aluminum? I like the pencil calculations visible on the top machined surface.
It also looks pretty low-perf to me.
R.
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2486989
04/23/18 10:02 PM
04/23/18 10:02 PM
Maniford is Aluminum
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2487056
04/24/18 12:14 AM
04/24/18 12:14 AM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
[img]https://www.jalopyjournal.com/forum/attachments/upload_2014-10-11_10-13-23-png.2735205/[/img]
This is a pre-'55 331 hemi with an aftermarket intake and stock heads. Notice the water outlets in the manifold. What you have, and I said it before, is an aftermarket intake for a '53 or '54 Chrysler 331 Hemi.
Centerline
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2487678
04/25/18 09:50 AM
04/25/18 09:50 AM
I will have it on display in the museum. Will be a fun conversation piece. I'll have answers from around the web shown so people can figure out for themselves what they believe it to be. Got it as part of a package of stuff, including a hyper pak setup.
Re: Can anyone identify what this intake manifold? [Re: McCandlessboy] #2487780
04/25/18 01:54 PM
04/25/18 01:54 PM
moparx Offline
moparx  Offline
you don't see "hyper pak" stuff every day !
beer
