v belt squeals #2485660
04/20/18 04:19 PM
04/20/18 04:19 PM
arizona usa
O
oldschool Offline OP
O
arizona usa
I don't think i have ever had this problem.3000rpm and above,belt that runs water pump, p/s pump squeals.I have sanded pulleys changed w/p,tried different fan combos nothing helps.Its a new set up,squealed from day one.383 .040 over, pulleys off a 440 m/h.pulleys align with straight edge and don't wobble.please help,pulling what hair i have left out.thanks ,BILL
Re: v belt squeals [Re: oldschool] #2485664
04/20/18 04:23 PM
04/20/18 04:23 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
popcorn
Inquiring minds want to know....
I currently have the same issue kicking my azz!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: v belt squeals [Re: oldschool] #2485671
04/20/18 04:36 PM
04/20/18 04:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Belt sitting down in the pulley grooves correctly? There is a difference in belt angles and width. You might want to replace the belt anyway because once it starts squealing it gets heated up and hard so it will continue to squeal even if you have fixed the original issue.
Re: v belt squeals [Re: oldschool] #2485693
04/20/18 05:25 PM
04/20/18 05:25 PM
arizona usa
O
O
arizona usa
Yes,i have checked pulley grooves ,no wear in bottom of grooves and have changed belt 3 times now (gates).
Re: v belt squeals [Re: oldschool] #2485698
04/20/18 05:43 PM
04/20/18 05:43 PM
Andrewh Offline
Andrewh  Offline
never had it to fix, but have you considered changing the belt width?
I haven't looked in a while, but one of the numbers decides how wide it is.
go wider to see if it will grip better? or smaller to sit in the grove a bit more?
Re: v belt squeals [Re: oldschool] #2485759
04/20/18 08:13 PM
04/20/18 08:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The belt should fit in the groove tightly. If you show no wear in the bottom of the pulley then maybe the belt is too wide. It should go all the way into the pulley groove and show contact from the top to the bottom without bottoming out. In other words the belt angle and width should be the same as the pulley. General example, a 1/2" belt will work on a 7/16" pulley but still won't fit right.
Re: v belt squeals [Re: oldschool] #2485798
04/20/18 09:17 PM
04/20/18 09:17 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
add one of our serpentine belt kits with a spring loaded tensioner and no more belt squeal
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: v belt squeals [Re: oldschool] #2485832
04/20/18 10:45 PM
04/20/18 10:45 PM
I always thought that if a pulley or belt was worn enough that the belt touched the bottom of the groove that that WAS the problem (but I may be all wrong there). if your pulleys are aligned) & belt tight which I'm sure it is by now) then it about has to be wrong/worn belt (likely) or worn pulley (way less likely). Holler how it goes.
Re: v belt squeals [Re: RapidRobert] #2485843
04/20/18 10:57 PM
04/20/18 10:57 PM
IN
ahy Offline
ahy  Offline
IN
Is the whole setup original style? If anything has changed to reduce pulley wrap that has an impact. The fan seems to be toughest to drive.
If the fan clutch is extra tight or locked up that could be the problem. If your are running a viscous fan clutch (hope so) it should slip to a certain extent at higher RPM to help prevent fan overspeed and belt overload.
Also, FWIW, I believe I have run 3/8" belts in pulley's designed for 5/16" belt w/o problem.
Re: v belt squeals [Re: oldschool] #2485873
04/21/18 12:05 AM
04/21/18 12:05 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Cogged belt?
Ed
Re: v belt squeals [Re: oldschool] #2485889
04/21/18 01:09 AM
04/21/18 01:09 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
When ever I've experienced this before, I have corrected the problem wit all new (or different) pulleys and new belts. Once off the motor, I can usually see the wear on the pulleys. The sides of the belt groove are usually straight for about 1/4 of the depth before they tapper towards the center. This causes the belts bottom out in the groves and slip. If you look at the belts you remove, are the outside top edges worn away just a little, or maybe curled up a bit?
The alt and the bottom pulleys are often the ones most often damaged. We must change the water pump pulley more often, or maybe it is better material. Gene
Re: v belt squeals [Re: oldschool] #2485893
04/21/18 01:16 AM
04/21/18 01:16 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Every Gates belt Ive used squeals. Add a Dayco Top Cog and it goes away. Everytime.
Re: v belt squeals [Re: oldschool] #2486067
04/21/18 02:11 PM
04/21/18 02:11 PM
central il.
second 70 Offline
second 70  Offline
central il.
Old change the belts to dayco top cog as in earlier post. My hemi would throw and break belts at rpms until I switched. No problems in 8 years. I was able to get a deal on a bunch of different sized unused belts from a nascar team to see what length fit best. I ended up with the 15470 for alternator and 15440 for power steering.
The first 2 numbers mean it’s 15mm or 7/16 wide the last 3 are length. The last number can be a 5 for half inch. So if yours fix good just measure them in inches and add that number to the 15.
I will bet your problem will be over with the new belts.
Re: v belt squeals [Re: second 70] #2486278
04/22/18 01:47 AM
04/22/18 01:47 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
The first 3 numbers mean it’s 7/16 wide the last two are length so if yours fix good just measure them in inches and add that number to the 154.
The first 2 numbers are the width- 15 mm, the last 3 numbers are the length-47 and 44 inches long. All of our older Mopars were designed to use the 13 mm wide belts, pretty much unavailable today. 95 % of the Mopars use the 15 series belt which ride up out of the pulley a little amount.
Re: v belt squeals [Re: lemondana] #2486376
04/22/18 12:55 PM
04/22/18 12:55 PM
central il.
second 70 Offline
second 70  Offline
central il.
Thanks lemondana I stand corrected. I was going off of memory which wasn't working correctly. But I do know theses belts work.
