Re: fuel pump
[Re: 73Convertriple]
#248536
03/09/09 03:37 PM
03/09/09 03:37 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
motor runs but no pumping or is the motor dead?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: fuel pump
[Re: HealthServices]
#248537
03/09/09 03:40 PM
03/09/09 03:40 PM
Posts: 190 Motor City
73Convertriple
Motor City
motor dead.... Car was idling and it just quit. Had to struggle to push into the garage. Happened While winterizing last fall, at least it did not leave me stranded. Has power to the pump yes. first thing that i checked
Re: fuel pump
#248538
03/09/09 03:44 PM
03/09/09 03:44 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
No rebuild kit for the motor that I have seen .
Re: fuel pump
#248540
03/09/09 03:47 PM
03/09/09 03:47 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Take a hammer and tap on the the side a couple times. If the thing starts pumping the brushes are worn out. Buy a new pump as this will keep happening. Not rebuildable. Either way toss it. Or send it to me and $150 I will rebuild it. You will think it is a new unit after I'm done with it.
Allen
Re: fuel pump
#248541
03/09/09 04:08 PM
03/09/09 04:08 PM
JohnRR
U.S.S.A.
