69 Charger Fuel Pump/Line Question #2485191
04/19/18 05:29 PM
04/19/18 05:29 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
69 Charger 440, AVS carb. Carter website shows M4434 as correct fuel pump, with a 1/8-27 female inverted flare (output) and 5/16 hose barb input. Confirmed with their tech rep. Right Stuff website shows the RPC7001 pump to carb kit, 2 lines, for same application. Their tech rep said both lines have 1/2-20 male threads.
Is an adapter, 1/8-27 male to 1/2-20 female, commonly used for this setup, or is there an alternative fuel pump for the 440 with a 1/2-20 output thread?
Re: 69 Charger Fuel Pump/Line Question [Re: 70runner] #2486087
04/21/18 03:00 PM
04/21/18 03:00 PM
tucson az
frank Offline
frank  Offline
tucson az
I don't know about the specific adaptor but every time I've used a carter mechanical pump the local hardware store (ACE) had everything I ever needed to make it work.
Re: 69 Charger Fuel Pump/Line Question [Re: 70runner] #2486122
04/21/18 05:05 PM
04/21/18 05:05 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Do you,need to replace pump or lines?
The right stuff products are usually wrong and don't fit.
Sounds like their fuel line kit is wrong. I won't buy from them anymore.
This is a common line kit used on 3834bbls and 440 4bbls from mid 60's to end of 1969.
Try Fine lines or inline tube.
Re: 69 Charger Fuel Pump/Line Question [Re: 70runner] #2486147
04/21/18 06:03 PM
04/21/18 06:03 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Everything I bought from The Wrong Stuff was, well, Wrong. I wouldn't buy anything from them.
Re: 69 Charger Fuel Pump/Line Question [Re: 70runner] #2486163
04/21/18 07:17 PM
04/21/18 07:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 1/8-27 is a pipe thread. you'll need a 1/8" pipe/5/16" inverted flare fitting to screw into the pump (1/8-27 outlet port). once you get the inverted flare fitting everything else is simple and right-stuff may have the fitting.
Re: 69 Charger Fuel Pump/Line Question [Re: 70runner] #2487608
04/25/18 01:12 AM
04/25/18 01:12 AM
N
NITROUSN Offline
NITROUSN  Offline
N
If your pump has the 1/8 27 npt ports you need to have the brass fittings to go 1/8 27 male to 5/16 inverted flare which is 1/2 20 threads per inch. The line kit you are looking at will work as long as you have the correct pump and carb size fittings.
