Rpm ranges on these MP intake manifolds #2485106
04/19/18 02:18 PM
04/19/18 02:18 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
Does anybody know what the listed RPM range is on the following MP part numbers?
As I’m not having any luck finding a P4529117 anywhere in the USA
P4532060
P4532061
Thanks Moparts!
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: Rpm ranges on these MP intake manifolds [Re: mopar_leaner] #2485114
04/19/18 02:52 PM
04/19/18 02:52 PM
an8sec70cuda Offline
P4529117 is a newer number for P4532060. Same manifold, different part number.
I found a pic of the P4532061 and it looks identical to the other 2.
These are nothing more than aluminum versions of the factory cast iron HP manifolds.
I used to have the RB version on a 440 years ago. It's exactly the same as the cast iron piece...weight savings is the only advantage.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rpm ranges on these MP intake manifolds [Re: mopar_leaner] #2485157
04/19/18 04:19 PM
04/19/18 04:19 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
My guess would be 1,500-5,500.
Re: Rpm ranges on these MP intake manifolds [Re: mopar_leaner] #2485161
04/19/18 04:26 PM
04/19/18 04:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
stock type intake: 1000rpm-4500rpm. these may rpm a little higher but i'll bet power is dead at 5000rpm.
Re: Rpm ranges on these MP intake manifolds [Re: mopar_leaner] #2485661
04/20/18 04:20 PM
04/20/18 04:20 PM
Hermiston Oregon
Hermiston Oregon
This is what I have found out about this intake on-P4529117, the rpm range is from idle to 5800 and fits stage IV,V and production heads.
Re: Rpm ranges on these MP intake manifolds [Re: mopar_leaner] #2486339
04/22/18 11:27 AM
04/22/18 11:27 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What is your source for this?
If it is an intake that is fashioned after the factory intake for a 440, I agree with Lew. Power will drop like a stone at 5200. The intake is the cork on a factory 440.
If you insist on that intake and want to up the power and rpm range, mill the divider, add an open space as room allows, and cam up slightly from stock.
Re: Rpm ranges on these MP intake manifolds [Re: mopar_leaner] #2486353
04/22/18 12:12 PM
04/22/18 12:12 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
a few years back somebody on this website flow tested a stock intake and IIRC they got 200cfm. think about it. a stock head, which is inadequate for performance, will flow a little better than 200cfm. I don't think intake manifolds by themselves dictate peak rpm, but they will dictate a power range. I think valve train stability is more of the key to peak rpm. take what the marketeer's say with a grain of salt.
