leaf springs for street strip car #2485065
04/19/18 12:57 PM
04/19/18 12:57 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'm looking at replacing the original springs on my 73 cuda. The car squats noticeably in the rear. What seems to be the opinion on the best setup for a street strip car? The car is a 528 hemi with a 4 speed, so I want something that will help it hook. I don't want any of the springs that lower the rear that I see everywhere, but at the same time I don't want the back of the car to have a huge amount rake to it either. I don't mind if the car has a rough ride to it. I've read mixed reviews on the super stocks and caltracs. I understand the caltracs will give a slight E.T. improvement, but I don't really want to have the bars hanging doen low and causing any ground clearance issues.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: leaf springs for street strip car [Re: 73cuda340] #2485072
04/19/18 01:08 PM
04/19/18 01:08 PM
P
Porter67 Offline
Porter67  Offline
P
Look further into caltracks and there mono springs, I think they have there +1 ones that settle nice, the caltracks themselves ive never had an issue with them being too low and have never heard anyone else unless your pothole shooting and ditch jumping.
With your 528 the calvert parts will take it all and make it work.
Re: leaf springs for street strip car [Re: Porter67] #2485119
04/19/18 03:02 PM
04/19/18 03:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The Cal-Trac bars don't hang down and cause any ground clearance on my car. I did the super stock spring thing and they wear out after about a year and completely lose their arch.
I run mine all over on the street with Cal-tracs and love them!
'63 Dodge 330
11.19 @ 121 mph
Re: leaf springs for street strip car [Re: GY3] #2485124
04/19/18 03:09 PM
04/19/18 03:09 PM
an8sec70cuda Offline
iagree Same here. Cal-Tracs or Assassin Bars (very similar to Cal-Tracs) are as good as it gets for leaf spring traction. Both are about the same as far as ground clearance. I've never had a clearance issue w/ mine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: leaf springs for street strip car [Re: an8sec70cuda] #2485263
04/19/18 08:51 PM
04/19/18 08:51 PM
clarks summit pa
clarks summit pa
Do the caltrac mono leafs bolt right up, or are different hangers required? How is the handling?
Re: leaf springs for street strip car [Re: 73cuda340] #2485272
04/19/18 09:13 PM
04/19/18 09:13 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Maybe I shouldn't say this. I think if your 528 hemi with 4 speed hooks well that you will quickly destroy your 8.75 .
Re: leaf springs for street strip car [Re: forphorty] #2485333
04/19/18 11:25 PM
04/19/18 11:25 PM
iagree shruggy wrench
Stick shift cars drivetrain are cannibal, you must feed them parts twocents work
It can be tires, clutches, drive shafts, U joints, axles, rear end parts or what ever parts you choose shruggy
Of course you must remember also that your right foot controls how much power the engine feeds to the drivetrain work shruggy
Good luck either way thumbs
Re: leaf springs for street strip car [Re: 73cuda340] #2485351
04/19/18 11:55 PM
04/19/18 11:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I just did all this with my 71 Demon (stroker small block stick car which will soon be in the 600HP range). I went with a new Strange Dana 60, Caltracs bars with thier Mono leaf and 9 way adjustable shocks, etc. I also added a new Passon OD trans, drive shaft, new clutch, and a Lakewood bell housing. So far I'm happy
*The worst part of the swap? Installing the POS Lakewood Scatter shield.
Re: leaf springs for street strip car [Re: 73cuda340] #2485353
04/19/18 11:58 PM
04/19/18 11:58 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i have a 73 cuda not the fastest car ever 12.31 @ 110 .
i installed 460 & 461 ss springs in 1986 and they work perfect and have never saged !
type in, mason dixon mopar 2017 cuda and you can see me make a few runs.
Re: leaf springs for street strip car [Re: Cab_Burge] #2485398
04/20/18 01:16 AM
04/20/18 01:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, I had to step up to a Dana 60 and 1350 u-joints. My car kept finding the weak points in the drivetrain last summer. Get a rear yoke that uses u-bolts while you are at it.
Sticky tires and power find the weak links. 4 speeds make it worse.
'63 Dodge 330
11.19 @ 121 mph
Re: leaf springs for street strip car [Re: calrobb2000] #2485399
04/20/18 01:18 AM
04/20/18 01:18 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By calrobb2000
hi
The early Made In America ones were great. The current ones are made in Mexico. They lose arch quickly. It is well documented.
'63 Dodge 330
11.19 @ 121 mph
Re: leaf springs for street strip car [Re: 73cuda340] #2485404
04/20/18 01:36 AM
04/20/18 01:36 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd say go directly to the Caltracs setup, with a Dana 60, or at the very least a backbrace on - and serious parts in - the 8.75, if sticky tires are planned.
Back in the '60s the SS Hemi cars were bending the 8.75s hooking what they had back then; Missile VI went into Famoso's return road sideways, and it got captured on film.
Re: leaf springs for street strip car [Re: 73cuda340] #2485416
04/20/18 02:00 AM
04/20/18 02:00 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yes, they bolt in.
I live out here in the Kansas flatlands so about all the "handling" I see is highway on ramps. That said, I have no complaints. They will make some "clicking" noises as they articulate. Nothing too annyoying, though.
'63 Dodge 330
11.19 @ 121 mph
Re: leaf springs for street strip car [Re: 73cuda340] #2485432
04/20/18 02:53 AM
04/20/18 02:53 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
What about Tri City Competition springs?
Re: leaf springs for street strip car [Re: Wailin D] #2485510
04/20/18 11:14 AM
04/20/18 11:14 AM
clarks summit pa
clarks summit pa
I plan on putting a dana 60 in as well, just haven't gotten to it yet.
Re: leaf springs for street strip car [Re: 73cuda340] #2485516
04/20/18 11:28 AM
04/20/18 11:28 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I agree with the many that recommend Cal-Trac springs and bars.
Give them a call, they have great customer service and can help you pick the right spring and ride hight you want.
Good luck,
Bill
Re: leaf springs for street strip car [Re: 340Cuda] #2485850
04/20/18 11:05 PM
04/20/18 11:05 PM
clarks summit pa
clarks summit pa
How do the mono leafs handle on the street in corners?
Re: leaf springs for street strip car [Re: 73cuda340] #2486626
04/23/18 12:16 AM
04/23/18 12:16 AM
clarks summit pa
clarks summit pa
Does anybody run these on the street?
Re: leaf springs for street strip car [Re: 73cuda340] #2486681
04/23/18 01:59 AM
04/23/18 01:59 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just fine
Re: leaf springs for street strip car [Re: Cab_Burge] #2486700
04/23/18 03:32 AM
04/23/18 03:32 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
When you have pets, you have to let them eat LOL
Free advice and worth every penny...
Factory trained Slinky rewinder.........
