Angle gauge on base of distributor? #2484690
04/18/18 04:36 PM
04/18/18 04:36 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Trying to come up with a simple way to know how many degrees I've moved distributor vs. using timing light every time.
I currently mark the distributor and the block where I know, at a glance, where 36° total is for me.
Since I started playing with nitrous, I retard different amounts for different tuneups.
I thought about using the base of a torque angle gauge or degree wheel and some way mounting it to flat base of the distributor. I googled 360° 2.25" angle gauge and didn't come up with much.
Yes, I know there are MSD controllers that allow you to retard/advace but was trying to keep it old school.
Any ideas?
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: GY3] #2484696
04/18/18 04:58 PM
04/18/18 04:58 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
They make these for Chevy engines. Might be possible to make something similar for a Mopar???
http://static.speedwaymotors.com/RS/SR/Product/54526100_L.jpg
Re: Angle gauge on base of distributor? [Re: Neil] #2484697
04/18/18 05:03 PM
04/18/18 05:03 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Cool! I've never seen one of those.
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: GY3] #2484732
04/18/18 06:12 PM
04/18/18 06:12 PM
AndyF Offline
AndyF  Offline
Shouldn't be too hard to fabricate something. I mark my crank trigger brackets with a dimple every 2 degrees so a person and adjust the timing without a timing light.
Re: Angle gauge on base of distributor? [Re: AndyF] #2484757
04/18/18 07:29 PM
04/18/18 07:29 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yep, just looking for ideas at this point.
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: GY3] #2484774
04/18/18 07:56 PM
04/18/18 07:56 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yep, I thought I recalled seeing those at some point. I'd like to have something like that for my car, too.
Re: Angle gauge on base of distributor? [Re: Neil] #2484782
04/18/18 08:11 PM
04/18/18 08:11 PM
I seen it when I was employed there but I never thought (at the time) to see about modding it for us.
Re: Angle gauge on base of distributor? [Re: GY3] #2484789
04/18/18 08:33 PM
04/18/18 08:33 PM
P
Porter67 Offline
Porter67  Offline
P
You would be amazed what a simple red or black sharpie dot on the lower edge of the dizzy where it sits on the block and then one on the block. A sharpie mark can last for several years.
No need to overthink the simple for no more then your doing.
Have a black dot on your dizzy, match it to a black dot on your block for na, and a red dot for spray. Check one time a year with a timing light for chain stretch.
Re: Angle gauge on base of distributor? [Re: Porter67] #2484791
04/18/18 08:36 PM
04/18/18 08:36 PM
^^^ Ding ding ding we (may) have a winna. time it/make your reference dots/should all be good.
Re: Angle gauge on base of distributor? [Re: Porter67] #2484793
04/18/18 08:37 PM
04/18/18 08:37 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
That is what I'm doing now and have done for quite a while. Not a problem for one or two points but with multiple different settings for different N2O jettings, was thinking I could do it better...
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: GY3] #2484798
04/18/18 08:48 PM
04/18/18 08:48 PM
for multiple points it would seem like a (very) good addition. I used to run around in Wichita decades ago (I lived down on hydraulic avenue) back when BTK was doing his thing.
Re: Angle gauge on base of distributor? [Re: GY3] #2484799
04/18/18 08:49 PM
04/18/18 08:49 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Chevy ones are actually a pain to see in a passenger car as the distributor is in the back up against the firewall and buried. A Mopar BB engine has the dizzy up front so it would be way easier to see.
Re: Angle gauge on base of distributor? [Re: GY3] #2484801
04/18/18 08:52 PM
04/18/18 08:52 PM
P
Porter67 Offline
Porter67  Offline
P
MSD parts play well with mopar dizys, you could run a newer box and pull it out with a laptop or with a older box like a 6al you could easily hide the lil msd chipped retard box.
Alot of fun for not alot of money is the nos mini controller with alot of features since your going deeper into it. Ramping it is a bit turbo like power.
It looks like your hooked, be careful, it only takes one mistake to get bit.
Re: Angle gauge on base of distributor? [Re: RapidRobert] #2484822
04/18/18 09:33 PM
04/18/18 09:33 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I live near Andover now but back before he got caught, we discovered my son went to a private daycare less than a 6 houses down from where BTK lived! shock
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: Porter67] #2484824
04/18/18 09:36 PM
04/18/18 09:36 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yep, already have an older analog 6AL box hidden under the battery tray but triggered by a Mopar electronic distributor. I also have a Leash single stage board for the nitrous. May just buy the #8680 MSD adjustable timing contoller...
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: GY3] #2484830
04/18/18 09:49 PM
04/18/18 09:49 PM
P
Porter67 Offline
Porter67  Offline
P
Them are nice proven little units, I only got the chip retard box because of the added start retard feature.
Looks like a bill fifty for the 8680, which isnt bad in todays world.
Re: Angle gauge on base of distributor? [Re: Porter67] #2484841
04/18/18 10:08 PM
04/18/18 10:08 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I did a seperate, dedicated fuel cell mounted up front with an electric pump to feed only the fuel solenoid. I played with the 100 shot jetting first and everything went well, bumped to 150 shot and it is a riot! I have jets for up to 250 but really should change out the plugs for colder for anything past what I'm doing now.
Lots of fun on the street!
I used to be able to hook from a roll in first at 30-40 mph with the ET Street Pro's but now it squirts sideways and MOVES OUT once I bang 2nd! drive
'63 Dodge 330
11.19 @ 121 mph
Re: Angle gauge on base of distributor? [Re: GY3] #2484927
04/19/18 01:46 AM
04/19/18 01:46 AM
Who is BTK?
Re: Angle gauge on base of distributor? [Re: Cab_Burge] #2484933
04/19/18 02:30 AM
04/19/18 02:30 AM
Dennis Rader the Wichita Kansas serial killer (BTK-bind/torture/kill)
Re: Angle gauge on base of distributor? [Re: GY3] #2485019
04/19/18 11:27 AM
04/19/18 11:27 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Interesting thread. Watching.
